Axle Swap
Old May 29, 2013 | 11:15 PM
broodog's Avatar
broodog
Axle Swap
looking to convert my 1994 4x4 SRW powerstroke to a DRW. Having trouble locating what axles arer, would the axles from a 1990 4x4 ford f350 460 work?
Old May 30, 2013 | 05:28 AM
tjc transport's Avatar
tjc transport
i ain't rite
yes, as long as they are from a F-350 pickup.
Old May 30, 2013 | 06:48 AM
fordman67's Avatar
fordman67
Because cab-n-chassis had diffetent frame widths than pickup trucks.i think that's what tom is saying iirc.
Old May 30, 2013 | 07:02 AM
broodog's Avatar
broodog
Great point. The 1990 is a single cab with a flatbed so very well could be cab n chassis however it looks as it is only a short bed truck, aren't chassis trucks typically 8 to 10 ft beds? Just for future knowledge how much of a difference are you talking?
Old May 30, 2013 | 07:39 AM
DIYMechanic's Avatar
DIYMechanic
IIRC there is 3" difference in the widths of the spring perches on the C&C trucks. Measure the width between the spring perches on the axle you have in the truck now and see if the one you're looking at is the same. It will be easy to tell if it's the same or not.
Old May 30, 2013 | 08:52 AM
tjc transport
i ain't rite
cab chassis could be ordered with an 8 foot frame.
measure the spring perches. if they are 33 inches, it is a CC rear and will not work.
if it is 36 inches, it is a pickup rear and you are golden
Old May 30, 2013 | 09:11 AM
DIYMechanic
Unless you're good with a welder and don't mind moving the spring perches. In that case the C&C axle would work too wouldn't is Tom? I'm not aware of any other differences to the axle, other than the location of the perches, but Tom would know better than I do.
Old May 30, 2013 | 09:40 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Cab and Chasis have shorter axles.
Old May 30, 2013 | 11:12 AM
farmert's Avatar
farmert
If your 94 came from the factory with a bed installed, you will need an axle from a dual wheel truck that had a bed installed from the factory. A 2 wheel drive axle will work, providing the ratio is compatable with the front of your 94. The cab and chasis axle will not bolt up to the springs on a truck that came from the factory with a bed installed.
Old May 30, 2013 | 11:39 AM
tjc transport
i ain't rite
correct. the CC axle is not as wide as the pickup axle, and will not work with dual wheels even if you do move the perches.
unless of course you get different rims with a deeper offset.
if memory serves correct, the CC axle is about 3 inches narrower overall than the pickup axle
Old May 30, 2013 | 12:47 PM
DIYMechanic
See there!? You learn something new every day! I stand corrected.
Old May 30, 2013 | 12:53 PM
tjc transport
i ain't rite
don't worry Nate.
someday, you will be older than dirt and forget more than you remember too!!
Old May 30, 2013 | 01:28 PM
DIYMechanic
I'm getting there Tom. Sometimes it's hard to tell whether I am learning something new or just having someone else remind me of something I have already forgotten!
Old Jun 9, 2013 | 02:08 PM
broodog's Avatar
broodog
could i just put dually hubs on the 250 axle or how much work is it to switch out the axle? I want to keep the front axle SRW.
Old Jun 9, 2013 | 05:02 PM
farmert's Avatar
farmert
You could use the 2" adapters to allow you to mount the dual rims on your 250 axle, the down side is you will get more wear on the outer wheel bearings as the adapters move the load center more to the outer bearing. Depending on how you go about swaping axles, if you leave the springs on the axle, 4 bolts need to come out that hold the spring to the truck, along with the parking brake cables that need to be unhooked, the u-jount disconnected, and one brake line. If the springs stay on the truck there are 4 u-bolts that hold the axle to the spring, along with the rest mentioned above. The true dual wheel axle that came from the factory with a pickup bed installed is 4 inches wider than a single rear wheeled truck. The dual wheeled cab and chassis truck is about 2 inches narrower than a single rear wheeled truck.
If I were doing the swap, I'd go with the factory dualed axle, and get the adapters for the front, so all the wheels would be the same.
Robert6401
Oct 24, 2016 11:46 AM
FullMetalJacket23
Feb 25, 2016 02:15 AM
MackGuy
Jul 16, 2013 03:44 PM
prisoner of gravity
Jun 10, 2008 10:34 PM
90CCDiesel
Dec 4, 2004 05:57 PM
