Convert Cab And Chasis 2015 ford F-350 to a Standard Dually Bed - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
Reload this Page >
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-24-2016, 11:55 PM
FullMetalJacket23
FullMetalJacket23 is offline
FullMetalJacket23 is starting off with a positive reputation.
I Really Need Help With this issue, any advice would help..
I bout a brand new Ford 2015 F350 With Bed and Chasis. Installed a Flat Bed on the frame and want to remove it and install a dually Bed on this frame........ The frame is not the same as your standard dually. I need help to Modify and install to this Truck since I don't use the flatbed..........
Old 02-25-2016, 03:15 AM
davester250
davester250 is offline
davester250 is starting off with a positive reputation.
Yes, the frame is different, so is the rear axle [it's narrower on the Cab&Chassis model].
Swapping the rear axle with a wider one, but it won't line up with the mounts on the cab&chassis.
After the axle swap, just putting a bed on the frame is unlikely to result in it lining up right with the cab.
You probably can do it, with enough time money and effort. But you probably will be ahead money and time-wise trading for a regular dually.
xXANBXx
02-16-2018 02:31 PM
mattdavis1984
2017+ Super Duty
12-14-2017 11:35 PM
Jterr
10-28-2016 09:28 AM
79-ford-f150
09-20-2016 10:24 PM
usmcdad
04-14-2016 02:24 PM
Quick Reply: Convert Cab And Chasis 2015 ford F-350 to a Standard Dually Bed
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
