So the CAC boots are good no cracks and clamped ,pull EBP and tube also check IAT2 senser, what is your boost reading along with ebp? make sure the connections are good.
What weight of oil ,the 6.0 and Injects like synthitic 5w-40 ,I use the Rottella,diesel klean is a great choise because you can find it just about anyware , Howes, and stanadine is good too.
Banaza35 in the Tech folders under 6.0 bible has every thing you need take a moment (under statement) and read thru them.
Yeah, I had heard of stanadyne for sure, so I'll look into diesel kleen. I have several auto parts stores within 2 miles of me. I have the bible and believe me, it gets referenced frequently!
Okay o4badford, I'll look it up. I just like to down load the engine compartment picture of all the sensors. Makes it helps my old brain remember better.
