Couple weeks ago I bought a donor truck with power steering and power disc brakes. The PO had switched it over to a straight six so the power steering bracket is wrong for my 352. I went to the yard yesterday to pull a bracket and while there I noticed a few different pumps. And I'm wondering if I have the wrong pump. Mostly because I can't see how I'm going to mount it to bracket I pulled.
So I'm going back to pick up a pump and I'm wondering which pump would be better. The two styles were basically the same except the fill tube on one was long and skinny and the other was shorter and wider.
They both fit the bracket. They both spin without much hesitation (are they suppose to spin freely or with a bit of a slush slush slush? )
Both of the pumps lined up to the holes. Other then saying that the fill / dipstick holes are different, I didn't see any other differences. The one on the donor truck is from a much more modern truck. It's plastic, somewhat pyramid shaped, just like you'd see on almost any modern car. If I could figure out how to mount it, I'm sure it would work great.
If the P/S pump has a plastic reservoir, it's from a 1978 and later F100/350/Bronco and Passenger Car (except '78/79's w/hydro-boost-uses the "canned ham" Saginaw P/S pump as do 1975/91 Econolines).
Plastic reservoir: The P/S pressure hose has a straight tube w/an o-ring on it...connects to the pump w/a qwik connect fitting.
Since FE engines were cancelled at the end of the 1976 model run, and the plastic reservoir pump is a differentshape than the steel reservoir pump, no FE P/S pump mounting brackets will fit it.
NumberDummy, im not sure how to leave a message for you so i see that u made apost here. I am looking for a transmission crossmember for a 1996 Aeorstar electonic 4 wheel drive model, the part number i have is FO9Z6A023C. Ive tried many internete searches and a few big online parts guys. Any ideas on how to find this part, all ford dealers says it is obsolete and not availabel
Thanks
Steve
I am looking for a transmission crossmember for a 1996 Aerostar electronic 4 wheel drive model, the part number i have is FO9Z-6A023-C
I've tried many internet searches and a few big online parts guys. Any ideas on how to find this part, all ford dealers says it is obsolete and not available.
1989 Aerostar all 2WD/AWD V6 from 5/26/1989, 1990/97 Aerostar all 2WD/AWD V6.
