Hot Start Issue....w/ SGII live data
Old May 28, 2013 | 12:08 AM
TinMan289's Avatar
TinMan289
Hey all - I have an 05 Excursion (built 8/05 w. 05 motor) that currently has 165k miles. I've only the truck just over 6 mos now, changed over to T6 and replaced oil and fuel filters (Motorcraft only) at 160k (unsure what oil was being used before). I'm due for another oil change in approx 300 mi when I'm going to take my first sample for analysis.
Within the past two weeks, I've had two separate no hot start episodes. Luckily, I was in the position to leave the truck be and return in approx an hour or two when the temps dropped and the truck starts up.
Using my SGII I recorded the following data:
At idle while at op temp (EOT 196; ECT 190):
IPR - 21.8
ICP - 584
VLT - 14.0
FMP - 48.5
KOEoff after shutting down at op temp:
IPR - 14.7
ICP - 1
VLT - 11.7
FMP - 48.0
Cranking while hot:
IPR - 77.4
ICP - slow climb peaking at 330
VLT - 9.6
FMP - 48.0
The batteries are mismatched, unsure on age but both advertise CCAs above 800.
To add insult to injury, this started occurring just days after I started smelling a fuel leak coming from under the hood when I shut down the truck. Now, the smell is prominent and can be detected just by sitting at idle either in a parking lot of at a light.
I'm thinking the dummy plugs and standpipes...but haven't heard anyone mention the fuel leak before, so I figured I'd through this out for the masses to digest.
If you need anymore figures feel free to ask...I can provide anything SGII will take!
Thanks.
Old May 28, 2013 | 12:17 AM
04badford's Avatar
04badford
Only fuel in the coolent via Degus bottle .would be a good place to start.
Old May 28, 2013 | 12:47 AM
BLADE35's Avatar
BLADE35
Sounds like you may have 2 problems
That's a Good Place to check for fuel^^^MARK the Coolant reservoir and watch for the Coolant leval to rise also you can smell coolant for diesel
I will add since Fuel Filters was Done so recent Might check the Caps see if they on tight and straight NO Cracks
As Fars as the HPO System would be worth checking this stuff before Teardown
Post these at KOEO--Low Idle--High Idle(2500rpm) Engine at Normal temp A/C OFF in Park
SO Get the Low & High IDLE before shutdown and No-Start
ICPV
ICP
IPR%
V-Ref
Pull the Plug on the ICP sensor on the next No-Start then try Probably Wont work this time but Never know
Old May 28, 2013 | 01:16 AM
mustang_309's Avatar
mustang_309
When you go in to do the standpipes and dummy plugs you may as well do the STC fitting and fuel pressure regulator blue spring upgrade.
Old May 28, 2013 | 07:59 PM
TinMan289's Avatar
TinMan289
Ok, guys - I have the SGII set and I'll gather those readings on the way home from work tonight. I'll have em posted up in a few hours. Thanks.
I'll also check the degas before I start her up for the ride home, too.
Old May 29, 2013 | 12:04 AM
TinMan289's Avatar
TinMan289
Ok...the update:
Check the degas bottle...found out that there is quite a bit more coolant in the res than there should be (can't say more now than before because I honestly never looked that closely at it other than upon initial inspection of the vehicle 6 mos ago). I marked the current level (hot temps) to see if it changes in the morning when everything cools down. Also, there was no fuel smell coming from inside the tank. The fuel smell seemed to be coming from the general area of the top of the motor. I checked the filter housings and there were no cracks - everything lined up.
Now for the the tech:
idle high idle
ICPV 4/5 4/5
ICP 583 1400
IPR 21.8 40.8
VREF .75/.82 1.74
And, of course...after I get home it feels like starting up hot like nothing's wrong.
Old May 29, 2013 | 12:15 AM
04badford's Avatar
04badford
sorry first thing that comes to mind is the O=ring on the fuel filter cap?
Old May 29, 2013 | 12:20 AM
04badford's Avatar
04badford
What are the Values at =koeo. low ( idiol).
Old May 30, 2013 | 06:44 AM
TinMan289's Avatar
TinMan289
My error in explaining...the first is low idle, with the backslash representing a wavering reading with low/high values and the second set is high idle.
low idle --- high idle
ICPV 4/5 --- 4/5
ICP 583 --- 1400
IPR 21.8 --- 40.8
VREF .75/.82 -- 1.74
I'll obtain the KOEO reading in a bit, and I checked the fuel filter rings and they're fine.
Old May 30, 2013 | 06:51 AM
mustang_309
The ICPV should be around .21 to .25 at KOEO and VREF should be 5 volts
Old May 30, 2013 | 10:56 AM
BLADE35's Avatar
BLADE35
your V-Ref is Off too should be about 5 Volts
Start checking SGII Codes
Fuha
Aug 1, 2017 09:34 AM
rapca
Dec 3, 2016 08:32 AM
IDI Diesel
Nov 4, 2014 01:06 PM
jmcboots
Mar 4, 2014 01:46 PM
Dstosh
Jul 27, 2011 08:33 PM
