Yeah figured that but need to get it back together. And don't really need more power than what it's got now so I should be fine. I don't like it sitting around.
Thanks guy's
John
Good call on the kit and the seller.
My #1 tip on rebuilding a turbo. Use a punch to index things and not a paint pen. I used paint pen and in my brilliance put the turbo housings in the solvent tank. Needless to say re-install sucked.
nrhx2009. That's Barder Turbo Service. Good seller. He also has a 66mm upgrade for our turbos.
What you just bought is a stock compressor wheel for our trucks though. Nothing upgraded about that wheel for us.
thats what i have in my truck met the guy as well when i picked up my turbo setup as he is a hour and 15 min north of me i have in in my truck with 1.0 housing and it spools good egts in check no problem
the housing have marks for assembly with arrows on the inside of them to use as reference marks also the stock housing has a flat rectangle on the backing plate that always faces up
