6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Best Intercooler Pipe
Old May 27, 2013 | 08:14 PM
TIRE FRYER's Avatar
TIRE FRYER
What is the best fitting intercooler pipe for the 6.4. Gonna do a Banks Intercooler real soon. Not to concerned about price, just want good quality and good fitment. Don't mind doing a little grinding, but I don't want to chop up the whole radiator support.
Old May 28, 2013 | 07:51 AM
senix's Avatar
senix
Check with Banks. I know they make some of the pipes for other models. They may make it for this one too.
Old May 28, 2013 | 11:07 AM
TIRE FRYER's Avatar
TIRE FRYER
Didn't see one on their site. I don't think they make one.
Old May 28, 2013 | 11:17 AM
senix's Avatar
senix
MBRP makes one I beleive. There is a slight mod required on the passenger side but not too bad.
Old May 28, 2013 | 01:59 PM
golfmedik's Avatar
golfmedik
Flo-Pro makes one too..that is the one I put on mine. IF you are talking this pipe.
Very tight fit, but I like it!
Old May 28, 2013 | 02:21 PM
TIRE FRYER's Avatar
TIRE FRYER
Yes. If you had to do it again would you get the same one?
Old May 28, 2013 | 05:55 PM
slowmans's Avatar
slowmans
I had a Spartan one and didnt like the fit, but my MBRP pipe fits perfect!
Old May 28, 2013 | 06:04 PM
senix's Avatar
senix
don't forget new boots
Old May 28, 2013 | 07:20 PM
slowmans's Avatar
slowmans
I upgraded to the Riff Raff boots, they fit great!
Old May 29, 2013 | 01:32 AM
TIRE FRYER's Avatar
TIRE FRYER
I already have the ones from dieselsite in a box waiting. Thanks for the heads up
Old May 29, 2013 | 04:26 AM
golfmedik's Avatar
golfmedik
It would be either the Flo-Pro of the MBRP. I talked with two different guys at different places and they both said that the 'quality' of the Flo-Pro looked better. They meant 'prettier'! Each said it either one would be fine. I just ended up with the Flo-Pro due to a couple pf other guys on here having one.
Yes, I probably would buy the same one again...it is a VERY tight fit and I cut some plastic shims to keep the tube from touching the support and A/C lines. I love the look and the little bit of a sound difference. Not much, but a better 'groan' at full throttle..
Old May 31, 2013 | 11:32 PM
TIRE FRYER's Avatar
TIRE FRYER
I'm gonna try the Flo Pro pipe. Thanks for all the input!
Old Jun 1, 2013 | 07:15 AM
golfmedik's Avatar
golfmedik
There is quite a bit of grinding to do, I hope you have access to an air 'die' type grinder. OH, and be careful around those A/C lines as that can get expensive if you touch one of those with the grinder. This is what it looks like when the stock one is in place
This was not enough grinding.
This is what it took to get mine through there. I could've taken the support loose, but I chose to leave it in place.
And after a sight touch of rattle can BLACK, this is what the finished product looks like on mine.
I like it!
Old Jun 5, 2013 | 03:50 PM
TIRE FRYER's Avatar
TIRE FRYER
I'm a Matco Tools dealer, I think I can find some tools. Thanks for all the info everyone!
Old Jun 6, 2013 | 06:30 AM
golfmedik's Avatar
golfmedik
OH, so now he's gonna rub it in!!!!
