6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Best Intercooler Pipe
Old Jun 6, 2013 | 11:16 AM
TIRE FRYER's Avatar
TIRE FRYER
LMAO! Ordered the Pro Flo pipe, intercooler is here, i'll put up pics when I put it all together.
Old Nov 16, 2013 | 10:28 PM
GHeTTo JOe's Avatar
GHeTTo JOe
did ya get them in yet? how it go? was it worth the money?
Old Nov 16, 2013 | 10:38 PM
TIRE FRYER's Avatar
TIRE FRYER
Ill get some pics up soon, sorry I forgot. A little more power, lot less turbo lag, you don't need to cut much of the core support to fit the pipe, and the Banks intercooler fits perfect in the same spot. Turns out my old stock intercooler was leaking a bit. Also did the dieselsite hoses and clamps, they blew off a couple times, but some re-tighten and re-adjustments later seems o.k.
Old Nov 17, 2013 | 12:12 PM
SANDDEMON08's Avatar
SANDDEMON08
Originally Posted by golfmedik
There is quite a bit of grinding to do, I hope you have access to an air 'die' type grinder. OH, and be careful around those A/C lines as that can get expensive if you touch one of those with the grinder. This is what it looks like when the stock one is in place
This was not enough grinding.
This is what it took to get mine through there. I could've taken the support loose, but I chose to leave it in place.
And after a sight touch of rattle can BLACK, this is what the finished product looks like on mine.
I like it!
WOW........ i proably would not have cut the core support up like that..... i ran the flow-pro pipe and only had to gind a small area about a 1/8 to 3/16 to get it to fit. There are pipes on the market now that will fit with no cutting or grinding that where not aviable when i did mine a few years ago. I would go with one of those now if i had a choice.
Old Nov 17, 2013 | 12:42 PM
SANDDEMON08
I best quality intercooler pipes I have seen are the no limit IC pipes. Great fit and great finish. You can find them in a kit with the boots from Elite Diesel and a few other venders, kit also includes the intake elbow if you are removing the EGR valve and doing an EGR delete as well.
Old Nov 17, 2013 | 01:16 PM
GHeTTo JOe's Avatar
GHeTTo JOe
ok maybe this is a dumb question but why do aftermarket intercoolers cost so dang much even compared to radiators?
Old Nov 17, 2013 | 03:33 PM
TIRE FRYER's Avatar
TIRE FRYER
Because they can...lmao! With my Spartan tune im pushing about 42lbs of boost, so I really did the full metal intercooler more for reliability. I also read the one from Banks has the most airflow through it for engine cooling, etc.
Old Nov 18, 2013 | 07:13 AM
Mystic_Cobra's Avatar
Mystic_Cobra
Does anyone have dyno sheets showing power improvements for these intercooler pipes? This is worthless without dyno charts!
jdeeg4276
Sep 17, 2011 08:33 AM
joe f350
Jul 17, 2011 10:18 AM
ccarrier
Dec 16, 2010 08:41 PM
TexasDiesel97
23
Sep 22, 2008 03:52 PM
Gary E K
Jun 4, 2002 03:56 PM
