Lets get some more pictures of light. I know there are 05 conversions out there to show off the lights and brightness. Also post up some pics of the lights that have the harness on them. Higher wattage bulbs and all.
2000 f450 7.3 I have on my headlight switch, the button pulls out for fog lights, there have never been fog lights on this truck. Im looking in to getting some. Because my switch pulls out, does that mean that there is wiring under hood or around headlights, pre-wired for fog lights? where do i look for them, is there a seperate fuse? Or do i need to run new wires to a new switch?
Thanks for your help,
Steve
My fog lights are on a seperate fuse. The wiring would be near the block heater plug for the actual lights. I'm not sure where they tie into the main harness, but I'm happy to look for you. When you pull out the switch, does the fog light symbol illuminate on the light cluster?
It should show amber if you are pre wired. I run H10 projector LED's in my fogs and they look good. I'll work on pics tonight.
I'm leaning this way. It was certainly worth it to upgrade to the clear '02 headlight housings from the fluted '99-'01 design. I think the next best step is a harness upgrade.
I changed to the '02 housing after the bride stuck a hen phez into one of the '01 housing.....I like the light much better. They provide a nice cut-off.
No Sir, nothing on dash lights up, never has, I have a 2000 450 and a 99 250 neither one lights up. Didnt even know there was a fog light symbol.
Prob jus wire me some up.
