Headlight Woes
After spending an hour or so trying to align my headlights, i decided to go to the dealer today, pay the 40 bucks and keep peace of mind. When they were finished, I happily drove home.
I take my family out to dinner tonight, excited about enjoying my evening drive, when I still see the choppiness of the lighting. I also compared the light distance against other cars. my lights are brighter in the low beam, but short in distance and height.
Here are a few shots:
http://img.photobucket.com/albums/v5...light_pic1.jpg
http://img.photobucket.com/albums/v5...light_pic2.jpg
http://img.photobucket.com/albums/v5...light_pic3.jpg
Not sure if it's standard or if it's the Silverstar ULTRA bulbs or the headlight manufacturer. I know of one member with the same issue. Is this normal for those with lightning headlights? Is this a photometric issue or am I an isolated case?
any advice would be appreciated
I would seriously doubt that it would have to do with the bulbs. Aside from my dislike of bulbs with a blue coating, the Silverstars, and Sylvania in general, are quality pieces. The Silverstars do have the filament moved to a slightly different position than one of their standard replacement bulbs, but it is just to give the beam a little more distance. It shouldn't produce anything like that if it were inside a quality headlamp housing.
A few questions:
Is the first pic low beams, and the 2nd highs? What about the 3rd?
I see they say the lights come with a "certificate of compliance", do they have any actual markings on the lens of the light itself?
I guess you've made sure that the bulbs are sitting inside the light correctly? They are centered inside the ring that "hovers" in the middle of the headlamp?
The reflector looks like a pretty good copy of the OE style (from the pics I saw elsewhare), but looks can be decieving.
Thanks for the reply. pic 1 was taken in a static position. pic 2 was driving a little down hill. the third was close to my garage door ( about 4 ft).
I have contacted the people i bought the headlights from and sent them pictures. I shall call them up tomorrow to follow-up. I may have to return these headlights.
where are you in Texas?
All low beam pics then huh? I didn't park the Lightning up against a wall to see the beam, but most (all that I've played with) lights that are "diamond style" have a pretty flat cut-off on the top of the beam (unlike yours). They, correspondingly, give a pretty sharp cut off on the ground when driving. The pics from the drivers seat are a little blurry, but it looks like they are giving off some pretty major "hot spots". Yes?
Glad you posted this, I was considering getting the same lights a while back (and still want some lightning units) but couldn't find anyone with experience with aftermarket units. Mine, with the higher output from my mods, give of a good amount of glare from the normal lenses. Thanks for the pics. Any chance you could get a better one from the drivers seat sometime?
For my own curiosity, I'm going to post a link to this thread in the Lighting section of the forums to get their responses. Hopefully the FTE gods allow it to stay
.EDIT: Here it is https://www.ford-trucks.com/forums/5...like-this.html
I was looking at a pic of the TYC lights, it doesn't appear that they even have the ring/cover around and over the tip of the bulb. Do yours? I notice they have the screws in place to mount it, but I don't see anything coming off of the screws. This could definitely be part of the problem if so.
I mean these (supposedly TYC units):
http://i20.photobucket.com/albums/b2...80-6131-01.jpg
Don't seem to have this (or anything close to it): http://i20.photobucket.com/albums/b2...r/svtcover.jpg
Am I correct? Is your bulb completely unshrouded? This is the "hovering" piece I was reffering to above.
Do yours have any codes near the bottom of the lens (HB5, DOT etc)? I can't see anything in my top pic that would indicate so.
Thanks
http://img.photobucket.com/albums/v5...dlight_pic.jpg
I guess we'll just have to wait for the L owners to respond. Let me know what you hear from the company.
Pretty sure I can make out ans SAE code in your last pic.
Bulbs: I initailly used the new Silverstar Ultra bulbs for my truck. It does beam the whitest light I have ever seen, but unfortunately, it's luminescent and hour life isn't good.
Here are some info about bulbs:
H1 (regular normal):
1550 lumens, 650 hours
Long Life (or "HalogenPlus+")
1460 lumens, 1200 hours
Plus-30 High Efficacy (Osram Super, Sylvania Xtravision, Narva
Rangepower,Candlepower Bright Light, Tungsram High Output, Philips Premium):
1700 lumens, 350 hours
Plus-50 Ultra High Efficacy (Philips VisionPlus, Osram Silverstar,
Narva Rangepower+50, Tungsram Megalicht, but not Sylvania Silverstar):
1750 lumens, 350 hours
Blue coated 'extra white' (Osram CoolBlue, Narva Rangepower Blue,
Philips BlueVision or CrystalVision, Tungsram Super Blue or EuroBlue, Sylvania Silverstar or Silverstar Ultra, which is just a rebrand of the
Silverstar product, also PIAA, Hoen, Nokya, Polarg, etc):
1380 lumens, 250 hours
I decided to purchase the brightest easily available ( GE Nighthawks) from Wal Mart and noticed that it was not as bright as the Ultras, but the beam projected a little more wider and further in my Lighting Headlights.
I then decided to put back my OEM headlights just to compare them and found that using the OEM and GE Nighthawks was a spectacular combo. I actually had brighter longer and wider beams and the beam height was back to normal.
So, If one decides that they want to keep their Lightning headlights, I strongly recommend GE Nighthawks at about 30 dollars. These bulbs do compensate a little for the short comings of the photometics of the headlights. As much as I loved the look of my Lightning headlights, I will have to stick with my OEM. I am now in the process of returning the lights.
Good to hear you're making it work. I'm running the Nighthawks right now myself. I took them out for a while because, in combination with my harness upgrade, they were throwing too much glare to oncoming traffic (getting flashed). Since they throw a little bit farther beam than the Sylvanias I adjusted them down a bit and haven't had anyone flash me in the week they've been back in. Now they are half way between where the Sylv. were and where they threw they beam originally.
Just because the whiter Ultras look brighter doesn't mean they are or that they are more effective. The coating that blocks the yellow spectrum can play tricks on your eyes, colors will seem more realistic and they tend to "stand out" more, in reality they are not the best option. Be comfortable knowing that, no matter the optical illusion, you have a better spectrum of light now. I won't get too far into it, but there is sound science behind the idea.
I was under the impression the Xtravisions were a +20% bulb, not +30%. Where is that info from? In my experience the Nighthawks are a bit brighter than the Xtra's, both of which are brighter than the S'Stars (ultra and regular). The info above seems to mostly agree. The Ultras are advertised as 20% brighter than STANDARD bulbs, 30% more life than regular S'stars. I think the regular S'stars were originally advertised as 20% brighter themselves. Doesn't disagree with your above post, just clarifying.
Just wondering, did you try the Ultras with your factory headlights. Interesting they would mess up the beam. Never heard of that before. Was one a little crooked or anything by chance?
EDIT: 1000th post! Woohoo!
I did try the Ultras with my OEM headlights resulitng in a beam a little wider and further. I was content with it until my curiousity got the better of me and I tried my OEM bulbs ( prior to getting Nighthwaks) and it threw much farther, wider and higher-though not as bright.
After I installed NightHawks on my OEM headlights, the results were amazing! As far the the crookedness, or chopiness, the Ultras with OEM headlights were smoother then the TYC lightning style ones. Must be the photometrics
Last edited by CobraXP; Dec 31, 2006 at 10:35 PM. Reason: removed remark from quote - 'sucks cock' removed
