A/C not blowing cold
Old May 30, 2013 | 06:17 PM
  #31
White 97 xlt's Avatar
White 97 xlt
I always use ambient temp +100psi for a high side reading... It's not perfect but it makes a good starting point...
90° +100 = 190 PSI..
75° +100 = 175 PSI..
Old May 30, 2013 | 07:05 PM
  #32
tjc transport's Avatar
tjc transport
i ain't rite
well, that don't work.
the stupid software runs everything together instead of letting it display as a chart.
Old May 30, 2013 | 07:19 PM
  #33
norfolknova's Avatar
norfolknova
Here is how I do it.
1. take the ambient air temp.
2. add 20 degrees.
3 cross this temp to a pressure. Your discharge pressure should be the new temps PTR pressure or less
here is a PTR chart
It wouldn't post the pic from photo bucket, but you can google R134a PTR chart and you will get a couple of hundred results
Matt
Old May 30, 2013 | 07:29 PM
  #34
norfolknova
Like I said in a previous post we need to know the system pressure and the ambient temop first thing in the morning.
The reason for doing it first thing in the morning is that every thing under the hood has had time to cool o ambient temp so there is no heat soak form the engine.
With the air I believe you ave in the system the R135a PTR chart will not be completely accurate because the air mixes with the refrigerant and changes the properties
Matt
Old May 30, 2013 | 07:37 PM
  #35
Diesel_Brad's Avatar
Diesel_Brad
Well I have no way of getting a high side pressure. I will get a low side pressure in the am when I leave for work
Old May 30, 2013 | 07:42 PM
  #36
norfolknova
That is all I need Brad is the low pressure side. take it before you start the truck with everything off. The high side and the low side will be equalized so all i need is thee one reading.
I leave for work about 5:15 in the am so I probably will not see th post till the afternoon. but with the PTR chart I attached you can see for yourself whee you stand with the system. Should there be no air the system then we will have to visit other things to figure out what is going on. But lets start with the basics.
matt
Old May 30, 2013 | 07:44 PM
  #37
Diesel_Brad
O, i didnt realize the truck had to be off. thanks
Old May 30, 2013 | 07:47 PM
  #38
norfolknova
This is the same method used for finding out if you have a bottle of refrigerant and you don't know the condition. You use the PTR and you can tell if you hva a good bottle of refrigerant or a contaminated bottle.
But yes, definatley truck off.
Matt
Old May 31, 2013 | 05:00 AM
  #39
Diesel_Brad
OK
Low side pressure is 90-95psi
Engine off and cool(shut off for 10 hours)
outside air temp is 64-65*
What is that telling me?
Old May 31, 2013 | 01:54 PM
  #40
norfolknova
With ambient temp at 65 degrees you should have seen about 64 psi. So you are 25-30 psi over what it should be, that tells Me with out a doubt that you have got air in your system. This also explains the extremely high discharge pressure when the unit is running.
The proper fix would be to have the system recovered, a pressure test conducted to find the leak, fix the leak, pull a deep vacuum and recharge with the proper amount of refrigerant.
What will happen when you get it fixed?
You will have even colder air coming out of your vents,
You will extend the service life of your compressor, running high pressures on your system shortens the compressor life.
You will have less load on your serpentine drive belt and therefore less load on the engine. After all it takes more power to compress something to 250 PSI then it does 150 psi.
If you have any other questions feel free to ask
matt
Old May 31, 2013 | 05:19 PM
  #41
Diesel_Brad
Thanks. I'll have to ask the body shop I worked at if I can use their machine
Varro
Oct 10, 2016 06:21 PM
jtre
Jun 15, 2016 07:41 AM
evenwill
Mar 30, 2015 11:46 AM
tomtank77
1983 - 2012 Ranger & B-Series
16
Jun 22, 2008 04:26 PM
dsquarewd
Sep 9, 2007 06:25 PM
