Help diff ratio
Old May 27, 2013 | 09:05 AM
fordf350camper's Avatar
fordf350camper
Help diff ratio
Hi every one i am in the Uk and i am trying to find out what rear axle i have and what ratio i have a 1987 ford E150 econoline.It has a petrol v8 auto. Thank you
Old May 27, 2013 | 09:57 AM
fordf350camper
Single rear wheel.
Old May 27, 2013 | 10:15 AM
JWC 3's Avatar
JWC 3
Divide the number of teeth on the pinion gear into the number of teeth on the ring gear .That will be your ratio . So 37 divided by 9 = 4.1111 which would be a 4.11 ratio .
Old May 27, 2013 | 12:01 PM
fordf350camper
Hi i have looked in the cab and on the door pillar this is what it says GAWR 3800 TYRES P235/75/15 XL PSI COLD SINGLE 41 then on the tag on the axle it says S124S 55 888 H 30
Old May 27, 2013 | 12:10 PM
JWC 3's Avatar
JWC 3
I think there should be another tag on there that states the ratio , if not removed . Otherwise the method above will tell you .
Old May 27, 2013 | 02:30 PM
fordf350camper
I think i have a 3.55 as i have noticed on the tag were the bolt hole is there is a number 3. Is this ratio any good as i want to fit the axle to my other truck that is dually wheels and just have this axle that is single wheel but fit a widder wheel.Or will i have to swap the ratio if i do have to do i just buy a diffrent ring gear.Who sells them thanks
Alcaeus
Sep 24, 2010 06:20 PM
Bino2
25
Apr 5, 2008 10:45 AM
RushN350
Dec 22, 2005 05:16 PM
rig_pig30
Aug 30, 2004 12:20 AM
X-1
Feb 26, 2004 01:04 AM
