Complete Truck
Category: Accessories
Price: $2000
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): S2000
Item Condition: TX
Engine: Part suitable for gas truck
Will need engine.
I have been told that I will need to replace/rebuild the engine as it sounds as if a main rod bearing has failed. Will still crank and drive. 5 speed transmission. Has a 6 inch skyjacker lift and a 2 inch body lift. I was in the process of lowering it when the motor started to make a noise. Air pump has been removed and I pieced the PCV system back together to help keep exhaust fumes out of the cab. I had the PCM rebuilt in the past year, distributor, coil, ignition module,front end work done, air horn removal. A/C works, PW, Power locks up front, manual in the rear. I am not able to part it out so I am looking to sell it to someone that may have the space to do so or has an engine to go in it. Located in Texas between Waco and Austin on I35. Just trying to keep it out of the scrap yard.
Corey
text/call if you need more info
254.307.2844
