FYI on the shipping end. Don't take the El Cheapo way out. Pad the heck out the box and buy a box rated for the weight times 1.5 to ensure your box makes it there. I've seen some really bad shipments comes in our warehouse on heavy items that half the stuff came up missing. Also ensure it for as much as it will take to get a new one.
I went to ups,I had it wraped with towels and duck tape,they boxed it and the plastic bubbles ,Red head had it back it seems like less than a week with pretty much the same packaging I sent.
Machining out the housings and installing needle bearings
Flame-spraying or replacing the shafts as needed Installing new control valves on some applications
Custom fitting each worm & piston assembly with special ordered, precise over-sized ball bearings.
Other things we do to produce a top quality product include:
Install every sector shaft on a lathe to check for straight and true,
polish the sealing surface to a higher polish than new.
Some original housings are manufactured without bushing or bearings. This is commonly seen in some Ford steering gears and Chrysler steering gears. We rebore these units and install needle bearings.
We use only the highest quality seals. All our seals are either O.E.M. or produced by two high quality, long time suppliers of our industry.
Probably the most unique and important thing we do is custom fit every single worm and piston assembly with new precision fit steel *****. This is a process not matched by any other company in the industry. This process is very important. The machining tolerances of the original manufacturing leave a small and varying amount of play that can be corrected in no other way.
Why don't other builders do this? It is expensive and time consuming to set up. This is one of the reasons you may find another unit somewhere else for less money but the quality cannot be beat. This is why we proudly declare that we are "Not the Biggest... Just the Best!"
Ok. I went to the parts store today too get the drag link I need and they have this really long one. It's a chassisrite rds917 but it's really long...am I suppose to get that one then cut to the right length ?
