Sponsored by: Real Truck
winch
Old May 26, 2013 | 05:44 PM
20015.4f350's Avatar
20015.4f350
winch
im looking to put a winch on my 5.4 f350 and was wondering what size winch i should get. also im hoping to put a plow on it at some point and didnt know if the winch would be in the way. thanks
Old May 26, 2013 | 05:47 PM
MC5C's Avatar
MC5C
Size of winch depends on what you plan to do with it and why. I have a 2,000 lb winch that I use for different things but it's about done winching a log out for firewood. It will probably interfere with a plow, but it depends on the plow. Lots of budget plows use a small winch to lift the plow blade.
Edit: - totally off topic but this winter I was stranded in a motel when we got 25" of snow one night. I watched a guy with a F350 6.7 PSD plow the parking lot, full of cars and drifts at least 4' deep, he had a plow with full hydraulic up/down, left/right and the ends of the blade could each angle in, and I had serious truck envy... that thing flat out worked!
Brian
Old May 26, 2013 | 11:49 PM
kd0axs's Avatar
kd0axs
If you're buying a winch to be capable of getting yourself unstuck, the absolute minimum you want is 1.5x the weight of your vehicle, and preferably 2x. On a Super Duty, this means you'll want something in the 12,000-15,000 lb range.
Old May 27, 2013 | 08:44 AM
Snowseeker's Avatar
Snowseeker
OOOOORrr You can get a lesser capable winch which is lighter and takes up less room and just get weight multipliers/****** block/pulley.
Old May 27, 2013 | 09:52 AM
redford's Avatar
redford
FTE Leadership Emeritus
Your choice depends on your budget. Get the biggest winch you can afford. Stop at 2X your truck weight if your budget is unlimited.
cowmilker08
32
Jan 8, 2014 11:36 AM
dalton1000
Jan 12, 2009 06:14 PM
2 stroke man
Dec 22, 2008 11:16 AM
shenders99
13
Feb 21, 2007 08:36 AM
Clouth
General Automotive Discussion
Nov 21, 2004 01:09 PM
