glow plug question
Old May 26, 2013 | 10:08 AM
tom18287's Avatar
tom18287
glow plug question
had my new dump for month or so, i have never seen the glow plug light come on ever. it has never struggled to start or anything and i know its spring but it got down into the 30s last night and when i started this morning still nothing. like i said truck has started perfect every time just don't get it.
Old May 26, 2013 | 11:11 AM
lundman's Avatar
lundman
I believe it only comes on when it needs to and I am guessing it is not cold enough. Wait until the winter and don't know where you are but when the temps drop then you should see it.
Old May 26, 2013 | 11:50 AM
powerstroke451's Avatar
powerstroke451
Well idk unless there is something wrong with mine because even when it has been around 90 here at the rig throughout the day, after my 13 hours working my glow plugs still cycle
Old May 26, 2013 | 12:00 PM
2ndStroke's Avatar
2ndStroke
Same here, even on a mild day I see my glow plug light, only pops up for a quick second or two though.
Old May 26, 2013 | 07:54 PM
tom18287's Avatar
tom18287
is there anything special you do to activte it? one click forward they should come on right?
Old May 26, 2013 | 08:09 PM
kper05's Avatar
kper05
When you turn the key to the on position, the glow plugs activate if needed.
On the 6.7L, the glow plugs can reach 2282°F in two seconds.
This isn't something you need to even think about, the PCM just handles it.
In colder areas, it is my understanding the glow plugs can even remain active after the engine is started as needed.
I always delay before cranking but I couldn't tell you the last time I looked for the glow plug light.
Old May 26, 2013 | 09:48 PM
Iowa Ford's Avatar
Iowa Ford
I wouldn't worry about glow plugs as Kper said, its automatic.
I was in upper Michigan last winter truck sat outside two days and was -13f when I started it glow plug light came on for 2 sec then it started immediately! also no power there so block heater was not an option I wont worry about it starting again
Old May 28, 2013 | 04:10 AM
Kjewer1's Avatar
Kjewer1
These trucks start incredibly well in the cold. I've had a similar experience, negative temps and the glow plug light comes on for the usual 1-2 seconds. I believe I also read in the manual or elsewhere that Ford doesn't even recommend plugging in until below -10 or so. Nothing like the 6.0 where I had to hit cycle the key 2-3 times when it was that cold.
Old May 28, 2013 | 09:29 AM
Iowa Ford's Avatar
Iowa Ford
I did notice when It's really cold, if I use block heater for 1/2hr before starting my fuel mileage is a lot better.
Old May 28, 2013 | 04:35 PM
Andrew010's Avatar
Andrew010
84° outside temp when I left work. Glow plug light came on for 1-2 secs like it does every time I start it and it's not already up to temp.
Old May 28, 2013 | 04:39 PM
SavageNFS's Avatar
SavageNFS
x2
Same for me.
Old May 28, 2013 | 07:41 PM
tolliewolly's Avatar
tolliewolly
It's 85 here and glow plugs came on for a seconds then went off. Everytime I start the truck the plugs come on. How long depends on the temp. Always starts great
Old May 28, 2013 | 09:02 PM
kper05's Avatar
kper05
The faster the engine warms up, the more efficient it will burn fuel so I can see that helping.
These trucks are not efficient when cold.
Old May 28, 2013 | 10:28 PM
Kjewer1's Avatar
Kjewer1
I wish I had control of the warm up enrichment tables in the ECU. They run them way richer than necessary for NHV and other reasons I don't care about. Most of my cars have zero warm up enrichment above 100 degrees or so ECT and they still run fine. If anyone knows of any software/tuning packages that provide access to things like this for these trucks please let me know.
Old May 28, 2013 | 10:42 PM
Iowa Ford's Avatar
Iowa Ford
I have even noticed the difference in mileage is even better after transmission temp finally gets up to where engine temp is running. So yes this truck doesn't do as well cold! but it never ceases to amaze me when I use it for what it's made for Pulling!!!
