Rear diff
Old May 28, 2013 | 10:20 PM
EXv10's Avatar
EXv10
Originally Posted by 51dueller
Not all rear axles have crush sleeves. His Dana 70HD uses shims instead. The crush sleeve if for setting proper pinion bearing preload (the bearings require a certain amount of pressure applied to them) NOT for keeping the pinion nut tight. The locking pinion nut does that itself.
Some do use shims but that nut won't stay there without pressure from the crush sleeve or shims......not going to argue about it.
Old May 28, 2013 | 10:22 PM
EXv10's Avatar
EXv10
The shims set the depth of the pinion gear and that nut won't stay there without pressure from the crush sleeve otherwise you could just leave the sleeve out and depend on the nut. They don't require a certain pressure, in fact that pressure disappears eventually. The drag is there to assure it is tight enough. The crush sleeve doesn't and can't set anything. The preload is set by the nut and it would quickly loosen without the pressure from the sleeve. You obviously don't know what you are talking about so I am done here.
Old May 29, 2013 | 07:45 PM
51dueller's Avatar
51dueller
Dana axles use shims either on the pinion or behind the pinion race to set pinion depth. It then has another set of shims that sit behind the outer pinion bearing which sets bearing preload.
This is taken directly from the Dana 70 service manual:
Note the last paragraph.
Crush sleeves serve the same purpose. Instead of using shims to set a specific dimension between the two pinion bearings, the pinion nut is torqued to squish the crush sleeve to the required dimension. Crush sleeve eliminator kits come with a spacer and final tolerance is set with shims.
When there is no bearing preload left in a differential is when its time to replace the bearings. I've rebuilt a GM 10 bolt, Sterling 10.25 and the Dana 70 in my truck.
If the shim or crush sleeve is used to keep the pinion nut from falling off? How do front hub bearings of FWD cars not have them to keep the axle nuts on? Those nuts are torqued to set a proper preload. I've seen them fail from over and undertorque, along with impact gun abuse.
Old May 29, 2013 | 09:57 PM
EXv10's Avatar
EXv10
I agree to the shims and recall using them now but these aren't FWD hub bearings. You make it sound like you can just leave the sleeve out and tighten the nut.......think about it.
Old May 29, 2013 | 10:36 PM
Riggins cleaning's Avatar
Riggins cleaning
Well after pulling the pinion out and inspecting it. There is no crush sleeve just spacers, the spacer between the gear and bigger bearing was destroyed. Any idea what size is supposed to go in between there.
Old May 29, 2013 | 11:25 PM
EXv10's Avatar
EXv10
No idea, the ones with spacers and shims are harder to set up. You can set the ones up with the crush sleeve and get the same drag if you leave the sleeve out but there is nothing to keep the nut tight which is why I say the only purpose of the crush sleeve is to keep the nut tight.
I hated setting up the ones with shims because you have to have the right shims on hand and you end up taking it apart and putting it together a bunch of times since there is a fine line between too loose and too tight........ugh. I haven't done those for many years but it would be easier if you used a dial indicator and a micrometer to determine the shim thickness(s).
Old May 29, 2013 | 11:41 PM
51dueller's Avatar
51dueller
Your the one that said the crush sleeve keeps the nut from coming off.
Yet I have never seen an axle that does not use a locking nut and every one I've removed to change pinion seals requires effort from the impact gun. The point is bearings need preload for long life. The higher the acting force, the higher the preload is to keep it in tolerance. The side carrier bearings on a Dana axle typically have 0.015" of shims over what would be considered zero lash. If the sole purpose of the crush sleeve was to just keep the nut from coming off, then manufacturers would just have a set torque spec for the pinion nut. Instead they do not give a torque spec and require you to tighten the nut to get a proper rolling resistance which can take anywhere from 300-600 ft lbs.
Riggins cleaning
There is no "set" specifications for the bearing preload shims. They service manual says to start at 0.060" and take a reading, then adjust the shims accordingly till you get the proper reading. This requires you to remove the axles and carrier from the housing. You will have to buy a pinion preload shim kit plus have a torque wrench capable of 250 ft lbs.
Here is a link to the Dana 70 service manual:
http://www2.dana.com/pdf/5312-9.pdf
Old May 30, 2013 | 09:38 AM
EXv10's Avatar
EXv10
Riggins cleaning
I realize all that but you could set the preload without the crush sleeve in there which is why it's only purpose is to keep the nut tight. I built hundreds of them and you're not grasping it.
Kevin Cwb Stpierre
Aug 4, 2015 07:26 AM
Rayrider911
Aug 27, 2013 02:33 PM
derek0525
Mar 18, 2013 12:20 PM
sanibel cobra
Dec 9, 2007 01:03 PM
