Rear diff
Old May 26, 2013 | 09:38 AM
Riggins cleaning's Avatar
Riggins cleaning
Rear diff
I need to know what kind and size differential I have in my 99 e350 box truck? It has the 5.4l and the 4r100 trans. I was cruising about 65mph and I heard a sound like a tire blowing. All tires are fine but now I hear a rumbling noise over 50mph and its definitely coming from the rear end. Any help with this will be greatly appreciated
Old May 26, 2013 | 10:02 AM
redford's Avatar
redford
FTE Leadership Emeritus
Hello Riggins cleaning, and welcome to FTE.
If it is the same as the trucks, it would be a Sterling 10.5.
Old May 26, 2013 | 10:06 AM
99f350sd's Avatar
99f350sd
Single or dual rear wheels? It could be the rear emerg brake came apart. Or bearings
Old May 26, 2013 | 10:48 AM
EXv10's Avatar
EXv10
Could be wheel bearings.
Old May 26, 2013 | 12:11 PM
Riggins cleaning
Its a DWR. it use to be a budget rental truck. I know for a fact that the the yoke going into the housing has a lot of play in it. I whines when I accelerate and goes away when I'm coasting, but now since that noise its rumbling.
Old May 26, 2013 | 12:17 PM
redford's Avatar
redford
OK, then it could be a Dana 80.
Old May 26, 2013 | 12:18 PM
99f350sd's Avatar
99f350sd
You mean the pinion behind the driveshaft? If so thats not good.. Its a dana rear. Don't drive it.
Old May 26, 2013 | 12:25 PM
Riggins cleaning
I pulled the numbers off the tag but they mean nothing to me but here they are
4.10 VCX2S AA
606145-1
so I'm thinking its a dana 80 but not 100 percent sure.
Old May 26, 2013 | 02:05 PM
Riggins cleaning
after doing some cleaning with the wire brush. I found on the side of the driveshaft I found some more numbers 70HD stamped into the housing. Am I right for assuming its a Dana 70HD differential?
Old May 26, 2013 | 02:17 PM
99f350sd's Avatar
99f350sd
nope can't use anything on the driveshaft.
Old May 28, 2013 | 05:49 PM
Riggins cleaning
Thins wasn't on the drive shaft it was on the diff housing it had 70 HD stamped into it. does all Pinion shafts have a crush sleeve
Old May 28, 2013 | 08:11 PM
Tom's Avatar
Tom
Correct, you have a Dana-70.
http://hillerford.com/resource_libra...cs/00econo.pdf
See page 44, about halfway down.
Moved to e-series van forum!
Old May 28, 2013 | 08:15 PM
EXv10's Avatar
EXv10
They all do and their only purpose is to keep the nut tight.
Old May 28, 2013 | 08:38 PM
51dueller's Avatar
51dueller
Not all rear axles have crush sleeves. His Dana 70HD uses shims instead. The crush sleeve if for setting proper pinion bearing preload (the bearings require a certain amount of pressure applied to them) NOT for keeping the pinion nut tight. The locking pinion nut does that itself.
Old May 28, 2013 | 09:21 PM
99f350sd's Avatar
99f350sd
What he said!
