302 running rough
Old Jun 8, 2003 | 04:58 PM
F150daniel's Avatar
F150daniel
302 running rough
it's a '79 302 stock auto
I started it today and it didnt want too start like the battery was low and when it started it ran rough Now that its warmed up some it starts better but it still idles rough it wont idle in gear.
Old Jun 8, 2003 | 07:18 PM
pfogle's Avatar
pfogle
302 running rough
I'd start with looking for a vacuum leak, then check the timing.
Old Jun 8, 2003 | 11:15 PM
jimfrentress's Avatar
jimfrentress
302 running rough
I had a buick that had the same symptoms, and it turned out to be a bad condenser (in the distributor.)
Old Jun 9, 2003 | 02:09 AM
71ranchero500's Avatar
71ranchero500
302 running rough
Dose your 302 run warm?
Old Jun 9, 2003 | 10:39 AM
F150daniel's Avatar
F150daniel
302 running rough
It starts easer warm but it still runs rough at any rpm, its doesn't sound like a steady skip.
Edit
I started it today and it idled realy rough and died after about 6 sec. I got it warmed some and it will idle but now the tach jumps from 600 RPM to 1,500 RPM ramdomly I think my coil is going bad it tested 9.1 OHMs between the + side and were the plug wire goes to the dizzy is this right?
Old Jun 9, 2003 | 05:58 PM
F150daniel's Avatar
F150daniel
302 running rough
I FIXED IT It was the timing, it some how set its self at 25 deg. BTDC I set it at 10 deg. ATDC thats closest I could get to 8 deg. BTDC with out pulling the dizzy
Chase Hanson
Nov 19, 2015 09:42 PM
Fummins
Feb 24, 2015 03:51 PM
MentalState
Apr 10, 2014 11:34 AM
ItsAFord55
Oct 20, 2012 09:35 AM
down2earth1928
Feb 1, 2011 05:10 PM
