Looking to buy tires for 2002 ex that has new v codes and in the process of adding 3" spring shackle lift.
Wanting to get the Cooper Discoverer a/t3 in LT275/65R20 but thinking it might be to narrow at only 11.1" wide. Has great reviews.
The second choice is the Toyo 35x12.5R20.
I've been told that once either tire is mounted on a 10" wheel, you could not tell the difference in the width. Looking for some good solid advice before making an expensive mistake.
Using Tire Size Conversion, the 275/65/20 shows as being 34.1x10.83x20. I just bought a Excursion with a set of wore out Toyo Open Country M/T's and the wear was pretty even.
