Sponsored by: Real Truck
Tire Size Translation
Old Apr 4, 2007 | 01:21 PM
RagdollRacer's Avatar
RagdollRacer
Could someone translate for me tire sizes: 265/75 = 30 in. tall by 10 in wide etc.
I want to buy a tire/wheel package for my 2003 F250 SD V10 and I would like to buy a 4" lift to install myself. But, looking at tire/wheel packages in maddening.
HELP!!!
Old Apr 4, 2007 | 01:42 PM
PowerStrokeHD's Avatar
PowerStrokeHD
The best way of finding this type of information is to go to the manufacturers website. As two tires of the same size from different manufacturers can actually measure different. Other than that all I can say is you have to be real carefull when choosing your tire/rim combo. With the leafs up front there is no room for error.
Old Apr 4, 2007 | 01:45 PM
Beerstalker's Avatar
Beerstalker
The first number is the width of the tire in mm. The second number is the section modulus or something like that. It tells you what percentage of the width is equal to the sidewall height. You multiply the width by the percentage and then double it and add the rim diameter to get the actual tire diameter. For example a 265/75R16 tire would be figure out as follows:
265/25.4=10.43" wide
265 x 0.75 x 2 = 397.5/25.4 = 15.65 + 16 = 31.65" diameter
So in english units it is pretty close to a 31x10.5r16
On edit - PowerstokeHD brings up a good point though, always double check the tire manufacturers dimensions because they sometimes round the numbers really strange. But to get the general size the calculations I used above will work.
Old Apr 4, 2007 | 01:52 PM
TXHillCountry's Avatar
TXHillCountry
You have it in your calculation there, but don't forget to highlight that to get from millimeters to inches, you divide the mm's by 25.4 (just in case anyone was wondering "where the heck does 25.4 come in" )
TX
Old Apr 4, 2007 | 02:02 PM
Beerstalker
Good point TX. I'm an engineer so I'm constantly doing that conversion (half the time in my head) so I end up assuming everyone else knows it. Same with going from lbs to kg (2.2046), people always think I'm strange when I do that in my head.
Old Apr 4, 2007 | 04:14 PM
RagdollRacer
Thanks for the help guys, that's just what I was looking for. I think I will do myself a favor and make up a cheat sheet so I have it readily available when shopping.
Beerstalker, you still may be strange though
Old Apr 5, 2007 | 11:56 AM
RagdollRacer
Look what I found:
<TABLE cellSpacing=0 cellPadding=0 width=239 align=center bgColor=#ccffcc border=1><TBODY><TR><TD noWrap>225/85R 14 = 29 X 9.00 X 14</TD></TR><TR><TD noWrap>215/75R 15 = 28 X 8.50 X 15
</TD></TR><TR><TD noWrap>215/85R 15 = 29 X 8.50 X 15</TD></TR><TR><TD noWrap>225/75R 15 = 28 X 9 X 15
</TD></TR><TR><TD noWrap>235/75R 15 = 29 X 9 X 15
</TD></TR><TR><TD noWrap>325/60R 15 = 31 X 12.50 X 15
</TD></TR><TR><TD noWrap>Q78-15 = 35.50 X 11.00 X 15</TD></TR><TR><TD noWrap>215/70R 16 = 28 X 8.50 X 16
</TD></TR><TR><TD noWrap>225/70R 16 = 28.50 X 9 X 16
</TD></TR><TR><TD noWrap>225/75R 16 = 30 X 9 X 16
</TD></TR><TR><TD noWrap>235/70R 16 = 29 X 9.50 X 16
</TD></TR><TR><TD noWrap>235/85R 16 = 32 X 9.50 X 16
</TD></TR><TR><TD noWrap>245/70R 16 = 30 X 10 X 16
</TD></TR><TR><TD noWrap>245/75R 16 = 31 X 10 X 16
</TD></TR><TR><TD noWrap>255/70R 16 = 30 X 10.50 X 16
</TD></TR><TR><TD noWrap>255/85R 16 = 33 X 10.50 X 16</TD></TR><TR><TD noWrap>265/70R 16 = 31 X 10.50 X 16
</TD></TR><TR><TD noWrap>265/75R 16 = 32 X 10.50 X 16
</TD></TR><TR><TD noWrap>265/80R 16 = 32.50 X 10.00 X 16</TD></TR><TR><TD noWrap>275/70R 16 = 31.50 X 11 X 16
</TD></TR><TR><TD noWrap>285/75R 16 = 33 X 11.50 X 16
</TD></TR><TR><TD noWrap>295/75R 16 = 33.50 X 12 X 16
</TD></TR><TR><TD noWrap>305/70R 16 = 33 X 12.50 X 16
</TD></TR><TR><TD noWrap>305/85R 16 = 36 X 11.50 X 16
</TD></TR><TR><TD noWrap>315/75R 16 = 35 X 12.50 X 16
</TD></TR><TR><TD noWrap>325/70R 16 = 34 X 13 X 16
</TD></TR><TR><TD noWrap>325/80R 16 = 37 X 13 X 16
</TD></TR><TR><TD noWrap>365/65R 16 = 35 X 14.50 X 16
</TD></TR><TR><TD noWrap>Q78-16 = 35.50 X 11.00 X 16</TD></TR><TR><TD noWrap>265/70R 17 = 32 X 11.50 X 17
</TD></TR><TR><TD noWrap>275/70R 17 = 32.50 X 11.00 X 17</TD></TR><TR><TD noWrap>285/70R 17 = 33 X 11.50 X 17
</TD></TR><TR><TD noWrap>295/70R 17 = 33 X 12.0 X 17</TD></TR><TR><TD noWrap>305/70R 17 = 34 X 12.00 X 17</TD></TR><TR><TD noWrap>315/70R 17 = 34.50 X 12 X 17
</TD></TR><TR><TD noWrap>255/55R 18 = 29 X 10.50 X 18</TD></TR><TR><TD noWrap>285/60R 18 = 32 X 11 X 18
</TD></TR><TR><TD noWrap>285/65R 18 = 33 X 11.50 X 18
</TD></TR><TR><TD noWrap>325/60R 18 = 33 X 13 X 18
</TD></TR><TR><TD noWrap>325/65R 18 = 35 X 13 X 18
</TD></TR><TR><TD noWrap>355/65R 18 = 37 X 14 X 18
</TD></TR><TR><TD noWrap>305/50R 20 = 32 X 12.50 X 20</TD></TR><TR><TD noWrap>305/55R 20 = 33 X 12.50 X 20</TD></TR><TR><TD noWrap>325/60R 20 = 35 X 13.00 X 20</TD></TR><TR><TD noWrap>355/60R20 = 36.50 X 14.00 X 20 </TD></TR><TR><TD noWrap>325/50R22 = 35 X 13.00 X 22
</TD></TR></TBODY></TABLE>
Jbhawx
2009 - 2014 F150
Jan 16, 2017 12:28 AM
Ben Tylka
Dec 8, 2016 04:50 PM
Reaper7906
Oct 27, 2015 10:16 PM
jeffnoel
Jul 10, 2007 10:19 AM
tastyklair
Dec 10, 2005 01:06 PM
