Sponsored by: Kumho
Tire Size Help
Old Feb 24, 2007 | 09:18 PM
Trailblazed's Avatar
Trailblazed
Tire Size Help
On my F250 V10 4x4, I currently run 255 85 16 tires. I bought my truck with these tires already on it.. Im not to happy with the appearance and performance of the tires. The tires appear narrow and dont have alot of traction.
Im looking to purchase a complete set of offroad/mud tires for my truck and wanted to know what the max. tire size I can go without rubbing the wheel wells..etc. My F250 has a 2 inch lift on it.
Also, I measured my tire from the ground up and it showed it was 33in.. does that sound right?
Any help is appreiciated.
Thanks
Old Feb 25, 2007 | 07:13 PM
1980F1's Avatar
1980F1
Go with 31's
Old Feb 25, 2007 | 07:46 PM
Trailblazed
Originally Posted by 1980F1
Go with 31's
Im not looking to down grade in tire size. If anything, I rather go bigger. Theres alot of room now with 33in tires left in the wheel well. I was thinking maybe 35s but not sure on the widths. Dont want my tire to rub.
Old Feb 28, 2007 | 12:09 PM
caseys's Avatar
caseys
In doing the math for the size of your tire the height is 33 inches.
To calculate the height of the tire using the tire size convert the width (in your case the 255 mm width to inches = 10.04 inches)
...then use: 2 (0.85)(10.04) + 16 = 33 inches (actually 33.068 inches)
For tires that are sized for example as: 31/10.5/15 ...the 31 is the overall height in inches.
