Stumped. Help.
Old May 24, 2013 | 05:43 PM
Sw1bpeo's Avatar
Sw1bpeo
Stumped. Help.
I have a 2000 F250 7.3 with 220000 on the odometer. Th truck runs great but has a nasty habit of idling real rough and then surging. Sometimes it stalls. I have changed the cam position sensor twice with no change. Used motircraft the second time around. I just dropped the tank, cleaned it out and out a new sending unit in. I know that needed to be do e as my fuel gauge was becoming unreliable. Also replaced the fuel filter and cleaned out the bowl and put a new drain assembly and gaskets all the way around. I though it would clear up after all that but it hasn't. Do you think it is the injectors? I'm stumped. Any help is greatly appreciated.
Old May 24, 2013 | 11:38 PM
powerstroke72's Avatar
powerstroke72
Moved to the 1999 - 2003 7.3L Powerstroke Diesel forum.
Old May 24, 2013 | 11:42 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Have you checked the tin nut on the IPR?
Old May 25, 2013 | 04:34 AM
Nsaan's Avatar
Nsaan
With doing all the work on the filter drain you must have hit the IPR wires. Like Greg said check your IPR coil, make sure the nut is tight, take the connection loose and check the wires in the plug also. I had those same issues with my truck and since reseating it I have had no more issues in the past year. Here's hoping it is as simple for you too.
flatbed777
Feb 3, 2016 07:09 AM
Eejayarr
Mar 28, 2014 07:41 PM
STIHL021
23
Feb 2, 2011 11:11 PM
dreamdiesel01
Apr 24, 2007 08:54 PM
fish4life
Nov 9, 2005 09:15 PM
