Bad Diesel
Old Apr 24, 2007 | 02:47 PM
dreamdiesel01's Avatar
dreamdiesel01
Cool Bad Diesel
Hi All,
This is my first post since I haven't had any issues with my 2001 f250 7.3. I think my problem is bad diesel. filled up today and chugging and smokin the entire way home. What to do before I get towed to mechanic. Should I drain the fuel and what is the easiest way to do so?
Opened up the pep **** on the water filter bowl and let it drain a bit . Started up hard and smokin still. Help please. Supposed to leave on long trip Friday.
dreamdiesel01
Old Apr 24, 2007 | 03:49 PM
Big tmiller's Avatar
Big tmiller
You might want to let it set for a at least 24 hours. then if you can put a ciphon hose down into the bottom of the tank and suck it out. Other wise you may have to drop the tank. check the fuel filter also. There are alot of very knowledgable people on here that will help you out. I am fairly new to this also.
Tom
Old Apr 24, 2007 | 03:56 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
welcome to the site dreamdiesel01,
id say ou might want to drain it asap, cause junk might settle up on the bottom of the tank and you have more problems with pickup screen getting cloged,
get a fresh diesel in the can, drain it all out, and put fresh diesel in, open filter bowl drain and drain it for a few seconds, to put fresh fuel in the bowl, that should do it,
Old Apr 24, 2007 | 04:14 PM
empiretc's Avatar
empiretc
First of all, Change your fuel filter. Draining it doesnt really help much, cuz bad diesel will plug the filter and it will run just as you described. Post a pic of the old one when you do it.
After my second encounter with bad diesel, I spent the $100 and did the hutch and harpoon mods.
Old Apr 24, 2007 | 05:02 PM
Tenn01PSD350's Avatar
Tenn01PSD350
dreamdiesel01
How much did you pump in there and was it a new station?
Old Apr 24, 2007 | 05:11 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Hi All,
dreamdiesel01
Welcome to FTE!!!
There is an anti-siphon valve in the top of the tank, so the best way to cmpletely empty it is to use the pump. If you disconnect the outlet line from the pump and jumper a constant 12V. source to it, it will pump the tank dry fairly quickly.
Old Apr 24, 2007 | 08:54 PM
F350-6's Avatar
F350-6
I used a hose on mine with a rag wrapped around it. Then I shoved the blow nozzle from my air compressor in through the rag with the pressure set about 30 psi and pumped the diesel out that way. You just need several 5 ga. buckets.
1985f250 6.9internat
Sep 25, 2013 11:56 AM
twom7
17
Oct 10, 2012 02:22 PM
Fuelhog 5212
17
Apr 26, 2010 06:23 AM
Smokin'
35
May 28, 2007 11:01 AM
460supercab4x4
Oct 29, 2006 05:39 PM
