help help help
Old Feb 2, 2016 | 09:30 AM
flatbed777's Avatar
flatbed777
help help help
88 f350 7.3 idi truck ran when I bought it, new lift pump, new sending unit new injector lines and return, new filter, all after I almost ran it out of diesel and now it surges down the road and sometimes will idle high like Rev up almost then die not sure what to do filter light stays on FSS is working I can hear it clicking is something just clogged up?? or is it a air intrusion, ip failure ? maybe my injectors pooped out? really just gettin aggravated at this Ole girl. if anything I'm good with wrench but not a pro. by any means, could yall maybe tell me wear to start?
Old Feb 2, 2016 | 12:04 PM
MtTheJeffro's Avatar
MtTheJeffro
running it close to low on diesel could have clogged the fuel filter.
also, search for "cone of death" on this site. The fuel pickup in the tank has a habit of causing serious fuel delivery issues.
Old Feb 2, 2016 | 12:31 PM
flatbed777's Avatar
flatbed777
just put new filter and new unit in the tank, still no luck
Old Feb 2, 2016 | 12:33 PM
flatbed777's Avatar
flatbed777
I have cracked the injector lines while at idle and they all get fuel??
Old Feb 2, 2016 | 02:13 PM
MtTheJeffro
Hit schrader valve on fuel filter housing to make sure you're getting fuel to that point. Next likely culprit is air intrusion
Old Feb 2, 2016 | 02:14 PM
MtTheJeffro
Filter light is what's bothering me here.
Old Feb 2, 2016 | 06:21 PM
PlumCrazy7's Avatar
PlumCrazy7
duplicated jeffro's post.
Old Feb 2, 2016 | 06:34 PM
speedwrench72's Avatar
speedwrench72
filter light indicates a vacuum being pulled on filter buy the transfer pump in the IP this means you have a plugged filter or a plugged fuel line between the filter head and tank, if it has a factory lift pump could have crap in lift pump lines or bad tank switch or plugged fuel line at tank switch some thing is plugged...fuel flow problem making it surge...
Old Feb 3, 2016 | 07:09 AM
tjc transport's Avatar
tjc transport
i ain't rite
surge is the injector pump running out of fuel. the filter light is injector pump drawing a vacuum in the filter like was already said.
i would get a portable fuel can and connect it directly to the lift pump. once you see it running good with no filter light there, start moving back toward the fuel tank. sooner or later you will find where the blockage is.
or you could try blowing out the line from lift pump to tank with low pressure compressed air.
but blowing out the line is a temporary fix, because whatever is in it will probably only get sucked back in.
jblueep
18
Jun 14, 2016 05:01 PM
mark's1984
Mar 25, 2016 05:23 PM
cvining13
13
Dec 29, 2015 10:46 AM
zax2000
15
Jun 1, 2011 07:30 AM
richardj
Nov 21, 2008 05:43 PM
