Rocker Arm falling off
Old May 23, 2013 | 12:36 PM
johnking's Avatar
johnking
I have an '05 F350 with the 6.0 that has 218K miles on it and the the other day it started missing and blowing blue smoke out the pipe. After diagnosis at the local shop we found the rocker arm on the #1 cylinder had fallen off! Push rod is straight, ball bearing was there and plastic retaining cap still appeared to be alright. Got a new retaining cap and put it back together. Fair amount of play/slack in the rocker arm after assembly but assumed that was due to no oil in push rod etc. as I had driven it for around 150 miles since it started missing before we took it apart. Started hard {which I understand is normal after removing the high pressure oil rail} and when it started there was a loud knock coming from the right front of the motor which went away after about 30 seconds or so and again assume that was due to no oil in push rod and it had to get pumped up. Drove truck about two miles or so on city streets with smooth acceleration, running great, no smoke, shifting smooth etc. -- then it all changed! Started shaking again, smoking like a French *****, shifting rough etc.
Any input would be helpful as to why the rocker has come off again {at least I assume that is what has happened} and or how to fix this so I can sell this nightmare of an engine.
Thanks in advance.
Old May 23, 2013 | 04:05 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Moved to 6.0 Power Stroke Diesel forum.
Welcome to FTE, johnking.
Old May 23, 2013 | 05:12 PM
mustang_309's Avatar
mustang_309
The lifter for that particular push rod has probably gone bad on you, just hope you haven't got needle bearings pulled through the LPOP.
Old May 23, 2013 | 06:16 PM
Rusty Axlerod's Avatar
Rusty Axlerod
^^ +1. When you go back in pull the lifter and check the roller on the tip where it rides on the camshaft. If it has a flat spot or is worn down it could easily damage the cam lobe. Getting the cam out requires pulling and significant tear down of the engine so hopefully it's ok.
Old May 23, 2013 | 06:47 PM
cheezit's Avatar
cheezit
flat cam, bad lifter or leaking injector causing hydrolock
Old May 23, 2013 | 09:31 PM
m-chan68's Avatar
m-chan68
The latter of the three would be the least expensive repair by far.
Old May 23, 2013 | 09:45 PM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE John, or am I talking to myself....
Old May 24, 2013 | 04:14 AM
Yahiko's Avatar
Yahiko
My kitties can hear you John.
They just ran off to do some hissing and play fight.
Sean
Brentella
Dec 2, 2017 10:25 AM
Lilbrowntruck
Apr 14, 2016 10:10 AM
huntke
Apr 9, 2012 02:10 PM
JoshuaHancock804
13
Dec 29, 2010 01:44 PM
mystic04
3.8 & 4.2L V6
Jun 21, 2009 03:39 PM
