New Mexico Chapter Join Chapter, Leader:
A/c mech.
Old 05-07-2013, 02:54 PM
beartracks's Avatar
beartracks
beartracks is offline
A/c mech.
Anyone in ABQ doing A/C work on the side? I would like to flush, evacuate and refill my 134a systme. I don't want to leave it with one of the businesses.
Old 05-14-2013, 09:05 AM
CelticDevilDog's Avatar
CelticDevilDog
CelticDevilDog is offline
Can't say I know anyone but I'll keep my ears open.
Old 05-24-2013, 09:28 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
I was surprised to learn that AutoZone has vacuum pumps and manifold gauges under their Loan-A-Tool program. If you know how to do it, that's a huge deal! Flushing is NOT recommended unless you know exactly what you're doing and have a machine that costs a fortune.
Old 05-31-2013, 04:46 PM
38Chevy454's Avatar
38Chevy454
38Chevy454 is offline
Flushing is easy, just blow compressed air through to get flush out. Just about any solvent is OK, I have used mineral spirits, but you can buy specific flush aerosol cans. Turn compressor by hand. Let it all dry out good. Works best to have all the parts disassembled. Then assemble with new O-rings, and make sure to oil the O-rings, and then pull the vacuum for around 1 hour to get any moisture out. Then pull vacuum again, shut it off and see if it holds. If good, then put new oil in (assuming you flushed compressor). Pull vacuum again and then charge up using gages. The key is to pull good vacuum for the 1 hour so any residual moisture or solvent will evaporate and will be sucked out.
stephenfaustin
06-04-2013 04:50 PM
Danger_Dave
10-11-2008 05:01 PM
JVAN
06-28-2005 12:59 PM
morepower16
01-28-2003 01:09 AM
levilevi2
09-06-2002 12:06 AM
Quick Reply: A/c mech.
