Gearvendor?
Old May 22, 2013 | 10:34 PM
austin79f-150ranger's Avatar
austin79f-150ranger
Gearvendor?
Has anyone put a gearvendor in their old ford to get better gas mileage? If so, what kind of mileage do you get?
Old May 23, 2013 | 12:34 AM
overlandexpress's Avatar
overlandexpress
I had thought of putting in a gear vendor, I have 3:00 gearing and my F150 with a 400 and C6 gets around real nice on the street, I even towed a loaded 21ft 7500lb toy hauler and it did great on the flats and right at 40 mph on the pass but towards the top I was down to 35mph, I must say it did it though and I was impressed but an F150 short bed is not the best tow vehicle for that kind of weight with 3:00 gearing! Which is why I'm restoring a 1973 F350 super camper special with 4:10 gears.
Old May 23, 2013 | 06:25 AM
miottimouse's Avatar
miottimouse
I have 2 installed in my trucks 79 f350 s/c 460/c6/3.73 ratio and a 78 f250 reg cab 502/c6/3.54 ratio both work very well they will drop the rpm aprox 600 rpm
3.73 runs 2100 rpm @ 60 mph 3.53 runs 1900 @ 60 mph I get about 12 mpg with the f350 w/3500 lb 12 ft camper and about 16 mpg with the f250 you can split the gears on these units 1/1 over 2 /2 over etc either leave in auto [4 speed] or 6 speed if you split works well with the camper unit in the hills you have a gear for every grade easy to install your self just make sure you get your driveshaft angle BEFORE YOU REMOVE IT or you will have a driveline vibration I am trieing something different with the f250 I will be making it in to a f150 with a ford 9" and 2.75 ratio and see how that works s/b be able to run about 1500 @ 60 mph but mind you my engines are all built for tork
Old May 23, 2013 | 08:36 AM
bucks77ford's Avatar
bucks77ford
* For the price of a OD unit, I bought a 01 Lincoln Continental with 90000 and it gets 25 MPG. Don't get me wrong, one of those OD units would be very nice in the old ford.
Those are some good improvement numbers.
Old May 23, 2013 | 02:42 PM
Blue and White's Avatar
Blue and White
From the example posted, the OD really helps Dent mileage.
I made the choice to put OD in a hot rod project. I know the payback isn't great in terms of calculated gas saved but there are other benefits. Its quieter, the engine lasts longer and cruise range on a tank is increased. Plus, once paid for, I can afford to drive it more.
Old May 23, 2013 | 06:59 PM
bucks77ford
Those would be the reasons why I'd want one. Fuel savings not so much just because of the minimal increase in the overall MPG compared to the expense od the OD unit, but lowering
the RPMs would be very nice. However, if fuel continues to rise and really gets up there than even a minimal increase in MPG can mean something. Here in MN fuel is 4.12
KyF350
Feb 1, 2018 08:09 PM
PartsPaul62
6.7L Power Stroke Diesel
Aug 21, 2012 06:50 PM
FMC
Mar 9, 2011 06:54 PM
sdrono
6.4L Power Stroke Diesel
16
Jan 30, 2009 10:18 PM
MSC
Aug 20, 2003 04:55 PM
