Bench seat
Old May 21, 2013 | 11:02 PM
lemasters f100's Avatar
lemasters f100
Bench seat
Will a bench seat from a 1987 bronco fit perfectly in a 78 f250 or are the brackets completely different?
Old May 22, 2013 | 05:51 AM
jim collins's Avatar
jim collins
I'm guessing you will need to use the brackets from your old seat too make it work. I haven't tried one but i think the floor pan is different. I did use the rear bench seat from a 87 crew cab by reusing my old 79 brackets, fit was perfect .
Old May 22, 2013 | 03:42 PM
lemasters f100
Is it easy to switch the brackets? What tools are needed?
Old May 22, 2013 | 03:54 PM
jim collins
One wrench to fit the bolts and nuts. Pretty easy for me , but i don't know what you can do. Is this your first time using tools on a truck ?
Old May 22, 2013 | 06:04 PM
lemasters f100
No I just wasn't sure if there was any welding needed to switch the brackets
Old May 22, 2013 | 07:16 PM
jim collins
I never had to do any cutting or welding using the pickup seat, bronco may be different. I have read on the forums that the pickup seat up to 96 goes in easy by switching the tracks.
Old May 22, 2013 | 08:47 PM
lemasters f100
Thanks for the help. Pretty sure it will be easy
Old May 23, 2013 | 11:26 AM
84espy's Avatar
84espy
For a beginner, bracket change will take approx 2 hours. Also, I recommend 1/4" drive sockets, if possible
lemasters f100
1978 - 1996 Big Bronco
May 22, 2013 11:15 AM
Denis in MI
29
May 18, 2011 10:56 AM
Nighthawk
Sep 16, 2005 11:07 AM
1968F250LWB
Jan 11, 2003 05:32 PM
