1966 Seat
Old Sep 14, 2005 | 12:03 PM
Nighthawk's Avatar
Nighthawk
Arrow 1966 Seat
Looking for some suggestions on replacing buckets with a bench seat in a newly acquired 1966 SWB, F100. What years would fit this vehicle without having to make any modifications? It has a floor stick but I'm considering putting an automatic (will also be floor mounted)
and'
suggestions on where to go look for one, other than the junk yard?
thanks,
Old Sep 14, 2005 | 02:43 PM
dendyr's Avatar
dendyr
Any seat will work it just depends on what you want to do to make it fit. My brother put a split bench in his 65. The seat came out of a 78 ford T-Bird I believe. He had to drill some new holes but it fit and it looks good.
Old Sep 14, 2005 | 02:45 PM
Nighthawk's Avatar
Nighthawk
thanks
thanks for the insight. It would be nice to find something requiring as little reto-fit as possible.
Old Sep 14, 2005 | 03:47 PM
ddavidv's Avatar
ddavidv
Most newer (1970s and 1980s) Ford truck seats will fit nicely if you use the 1966 bench seat brackets under them. The only thing you'd need to be careful of is that they don't require any more room behind the seat if you still have the cab mounted fuel tank.
Old Sep 14, 2005 | 07:48 PM
magee's Avatar
magee
I put a seat out of my 80 F150 and it fit fine. The seat's not centered exactly in the cab, but it sure beats the heck out of the buckets that were held in with the seatbelt (not my handiwork).
Old Sep 15, 2005 | 06:54 AM
jowilker's Avatar
jowilker
The floor pans are the same from 65 to 79 so for sure, those brackets are a direct fit. Seats on those brackets will work to 96, not sure beyond. I use the seat from the 76 donor that I bought, but the seat is a little wider and if your truck has arm rests you will have to open the passenger door to tilt the back forward. You will also have to cut the end off the latch to keep it off the gas tank.
John
Old Sep 15, 2005 | 07:57 AM
Nighthawk's Avatar
Nighthawk
Smile seats
gentlement one and all, thanks for the feedback. very helpful
nighthawk
Old Sep 16, 2005 | 01:43 AM
camperspecial65's Avatar
camperspecial65
Hawk....are those seats by chance out of a Mustang....like 65/6 type ????
cs65
Old Sep 16, 2005 | 07:11 AM
Nighthawk's Avatar
Nighthawk
don't know. just picked up the pickemup and they don't look like they would be from that vintage.
sorry,
NH
Old Sep 16, 2005 | 10:32 AM
daveengelson's Avatar
daveengelson
Put a 86 contoured split seat (fold down) arm rest in 65 f100. Went to salvage yard and looked for year(s) donor truck with same seat tracs as the 65, and with the wider bench. Found going to wider bench allows more options in selecting seat. Majority of later model back sections will all mount to the wider seats. Found an 86 contoured seat with the fold down arm rest and mounted the back section to a 68 bench. Then took the contoured bottom section of the 86 seat and put the springs, contoured material in a 68 bottom section of seat. Basically lazy and did not want to deal with modifying the seat tracs. Found if you have the wider bench and both arm rest should remove 1 that way wont have issue with gaining access to tank. Found reasonable uphostery shop and very pleased with outcome. Probably sound more complicated than it really was.
dave
Old Sep 16, 2005 | 11:07 AM
Nighthawk's Avatar
Nighthawk
Dave
great idea. i'll look into it and i suspect that more than the 86 will work just as well.
NH
pm042070
Jun 24, 2014 09:24 PM
bryan88
1966 - 1977 Early Broncos
Jun 11, 2012 06:34 AM
Retiredfire
Jul 5, 2008 08:11 PM
IICAP
32
Jan 3, 2008 03:38 PM
blueklutz
Nov 2, 2003 03:36 PM
