Turn Signal Cancel Switch #?
Old May 21, 2013 | 02:52 PM
wotan's Avatar
wotan
Can't find this plastic piece for the life of me....
Mine was driving me crazy trying to get my signals to cancel and finally I came on here to find a photo. My plastic piece is there but the long top and bottom feet have been broken off... I only have the two small feet at the top and bottom, not the longer "arms."
Anyone have a part #? Rockauto only sells the whole switch and the other ones I'm finding are only for 1973/74 trucks?
Planning on using the pins in my grant adapter... do they work OK or should I also try to find the cam that actuates this switch?
Old May 21, 2013 | 04:55 PM
OldStyle's Avatar
OldStyle
Rusty Roller
You'll need to find the correct one for your year but here is one for a '77.
Those "arms" are used to cancel the signal and they break....
Turn Signal Cam | AutoZone.com
Old May 21, 2013 | 08:58 PM
Poison Oil Racing's Avatar
Poison Oil Racing
I just bought one for my '77 from autozone. They actually had it in stock.
Old May 21, 2013 | 09:01 PM
fmc400's Avatar
fmc400
MSEE
Just a word of advice...it's really hard to install these properly. The wires coming off the cam need to snake through the switch very tightly, and it's difficult to get that to happen with solder joints in the path, without getting something pinched.
In my experience, if the cam is broken, it's best just to replace the entire switch. The clearance in this area is minimal, so even if you got it to work, it's likely a little close for comfort.
Old May 22, 2013 | 09:27 AM
wotan's Avatar
wotan
I was wondering about this when I took the old one apart last night. Not much slack in that wire and it's routed in a particular (stupid) way.
Old May 23, 2013 | 06:54 PM
V10man's Avatar
V10man
You guys talking about the red adn blue wires on the left?
Old May 23, 2013 | 07:08 PM
wotan's Avatar
wotan
I'm pulling my hair out with this one. I got the new cam and investiagated the wiring situation. I was able to route the new wires the same way and make my solder joints at the very bottom (right by the horn mechanism.) I figured I would be golden.
Put her back together and now here is what I have:
Running lights work all the way around.
4 way flashers all work, except right rear.
Left turn signal does not work on front.
Right turn signal does not work on rear.
Brake light does not work on right rear.
All of these lights worked fine yesterday except my turn signals didn't cancel.
Any bright ideas before I pony up $50 for a new switch?
Old May 23, 2013 | 08:54 PM
wotan's Avatar
wotan
Got it figured out... those little paper clip looking things on the back of the replacement cam come flush with the cam. They won't make contact with the pads underneath unless they are bent up slightly (they should press themselves against the pads.)
Took me a long time to figure that out but once I did -- everything now works absolutely perfectly.
Actually took the truck for a little maiden voyage. Made it 3 miles before I realized that the oil/temp/alt gauges weren't working. Just something else to tackle tomorrow I guess.....
Ken's74
Dec 20, 2017 07:43 PM
Mustangking1
20
Mar 26, 2014 08:16 AM
jd_sylvia
Jan 17, 2011 03:23 AM
jsutton
Jan 15, 2008 02:01 PM
ford390gashog
Jan 6, 2006 03:45 PM
