i have a 71 f100 with a straight 6 in it and i want to know if a aod trans will bolt up to it i have a c4 in it right now ... and if i can put a aod in it what do i have to do to make it right plz email me at
NOTE. Some places Ford calls it an AOD and some places call it an AOT when in a truck or van.
As noted above, you'll need the correct t/v cable, bracket that holds it to the Donor's intake, and maybe the Donor's carb. Since your C4 has a kickdown rod instead of the T/V cable the linkage lever must be different on your carb.
