Big Bob IFS front end
Old May 20, 2013 | 12:58 PM
Lawrence Petty's Avatar
Lawrence Petty
Have the Big Bob IFS front end - but no rotors sent. Have spindles GM 371876 RH & 371875 LH. Appears the bolt pattern to be 5 x 4 1/2" with 1/2" stud. The adapter/spacer that came with it seems to have that 5 x 4 1/2" with 1/2" stud to convert to Ford 5 x 5 1/2" pattern.
Parts store here states GM only had the 5 x 4 3/4" bolt pattern for that spindle. So need help finding the correct rotor so I can continue on my 1955 F100 project.
Old May 20, 2013 | 04:03 PM
raerjim's Avatar
raerjim
Isn't older Ford 5 X 4 1/2?
Old May 20, 2013 | 09:19 PM
ALBUQ F-1's Avatar
ALBUQ F-1
bump to top
Old May 20, 2013 | 10:23 PM
Mervy49's Avatar
Mervy49
5 on 5 1/2 is original.
Old May 20, 2013 | 10:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Look at the Questions on this Speedway kit's page, I think you are incorrect in assuming the rotors are GM parts. 1948-1956 Ford Half Ton Deluxe Disc Brake Kit, 5 x 4-1/2 Inch - Speedway Motors, America's Oldest Speed Shop
Old May 21, 2013 | 12:03 PM
Lawrence Petty
You are correct after some research - the rotor is Ford, I believe 77 or 78 Granada 11". Looks like the Speedway setup uses the original Ford spindle - so do not know if it will fit the GM spindle. The spindle has GM stamping on it (GM 371876RH-15). However the Ford rotor outer bearing hits the tapering up part of the spindle where it cannot be tightened correctly - too much play. So now, what Ford rotor fits the GM spindle? Would really like to know so I can get this truck up on the Big Bob IFS
MikePacey
May 29, 2017 08:30 AM
7375highboy
May 6, 2008 04:30 PM
fivfivf100
19
Aug 2, 2007 09:18 AM
chulsey12
Nov 26, 2002 06:34 PM
woodythx138
Jul 23, 2001 10:05 AM
