Door lock replacement - clip?
Old May 19, 2013 | 11:06 PM
astembridge's Avatar
astembridge
I'm replacing my locks today and stopped after getting the first one in. Is there a trick for installing the new lock clip? It was a major chore to get it to slide back in.
Old May 20, 2013 | 04:34 AM
CountryBumkin's Avatar
CountryBumkin
Should not be difficult. Perhaps the locks you bought have the clip groove machined slightly out of spec. Try sliding the C-clip over the lock before inserting it into the door to check fit. If it is real tight you might try filing a little material off the inside of the clip.
clintonvillian
Oct 23, 2014 11:05 PM
zsir
Oct 18, 2012 01:00 PM
rbaker6336
Apr 28, 2008 01:14 AM
fordblue_ca
Jun 17, 2004 05:23 PM
cg208cm
Apr 3, 2004 08:11 AM
