You need to check the voltage at the battery with the engine not running and again with it running.
Post back with what you read with a volt/ohm meter.
I had the same symptoms with my 2002 F-350 diesel. On my truck if I recall the engine-off battery voltage was between 12-13 (good) and with the engine running it was 13-13.5 (kind of low). I thought it might just be a voltage regulator issue and I might be able to go a long time like that. It ended up being about 2 years. Then I got stranded with totally dead batteries.
That was a different truck, quite a bit newer. But it gives one possibility
How long has it been since the brushes in the alternator were replaced? It's an easy procedure that cost about $10 if you buy them together and mounted on the plastic piece.
Sorry.I,m new at this. Do I just put volt meter on battery.? First with truck not running then with it running?
I don't know about brushes in alternator as I purchased vehicle used about a month ag. Battery is a year or so old
You are correct sir! Take a reading with the engine off, then with the engine running. The running voltage should be in the 13.5 - 14.5 VDC range. Perhaps a little higher.
