Stereo wiring
Old May 19, 2013 | 02:10 PM
Thomas Dezall's Avatar
Thomas Dezall
Stereo wiring
l am having trouble installing a Kenwood KDC-248U unit in my 1986 Class C ford motorhome....lt had an cassette ( auto-reverse)in it . The balance never was right in it since l got the unit. Anyway,l get a " protect" on the new Kenwood everytime l try to attach the speaker wires. Older FOrds usually had one ground , is that what could be causing my new deck to go into "protect"?
Old May 19, 2013 | 05:03 PM
Franklin2's Avatar
Franklin2
Yes. Read the instructions with the new stereo, most of the high power ones cannot have a common ground on the speakers. You will probably need to just abandon the old speaker wiring and run new.
To get the higher power from a 12v supply, the newer radios "pull" on the negative speaker wire at the same time they "push" on the + speaker wire. That's a primitive way of describing it, but is basically how they work and why you can't use a common ground. We can cross our fingers and hope the new stereo did indeed "protect" itself and didn't burn anything up inside.
albeitoneway
Apr 24, 2011 03:14 PM
amsuco
Nov 26, 2004 08:06 PM
gmerkman
Apr 1, 2004 11:23 AM
biggreen4x4
Jan 18, 2004 08:05 PM
MustangGT221
Jan 11, 2003 01:10 PM
