1996 F-250 stereo replacement
First step would be to hook a speaker up to the harness coming from the new head unit to verify that the head unit is working. If its working, then re-check all the connections. FWIW, on aftermarket stereos, I never use the factory harness unless I absolutely have to. Many times the factory just ties off the speaker negatives to a ground wire. Better off running new speaker wire.
jgrohs54
07-06-2015 10:13 AM
F-250 restorer
09-13-2014 10:37 AM
