Fuel Injector Cup Replacement
Old May 19, 2013 | 01:39 PM
glb4x4van's Avatar
glb4x4van
I have my fuel injectors out and noticed gasses seeped up past the compression washers on two of them.
Will replacing the washers be enough to solve this or do the cups need replaced as well?
The cups look ok visually after being cleaned.
Old May 19, 2013 | 02:01 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Replacing the cups is not common practice. As a matter of fact our Techs have posted previously that there is a tool for the job but it doesn't work well and head replacement is the preferred fix if the cups are leaking. Hopefully you don't have fuel in the degas bottle and the copper washers will fix it up. Be sure to clean out the threads the hold down bolts go in and torque to spec.
Old May 19, 2013 | 02:15 PM
glb4x4van's Avatar
glb4x4van
No, my degas bottle was clean anti-freeze. I just noticed the burnt residue on the two injectors. Replaced the compressor washers and o-rings and wasn't sure about cups.
Thank for the reply!
akblackfoot
Jul 29, 2017 05:58 PM
glb4x4van
May 9, 2013 11:40 AM
FordTrucksKickGM
1997 - 2003 F150
Jul 12, 2006 02:34 PM
Badfunkn
4 Cylinder Engines
May 29, 2002 12:58 PM
