292 intake manifold
Old Dec 3, 2005 | 10:20 PM
mason55's Avatar
mason55
292 intake manifold
I have a 292 in My 55' F100. The motor came with 3 manifolds, one of them is for a 2 barrel holley. The part# is B9EA-9425-B ... Will a 500 CFM 2 barrel Holly fit on this manifold ??? With the gas prices these days and since I have this manifold already I was hoping that this would work. Also if it does can I sand blast the manifold and powder coat it ? Any help or feed back before I have to go looking for a 4 barrel manifold and carb?
Thanks
Mason
Old Dec 4, 2005 | 09:01 PM
286merc's Avatar
286merc
It will bolt on as the original 2300 came out on the 57 at 300cfm. (that is a 59-60 manifold) I think 500 cfm in a 2 bbl will be too much; that is primarily a racing carb. Consider an Autolite/Motorcraft off a 60-70's SBF or FE.
Cheap to buy, easy to rebuild, decent performance.
Old Dec 4, 2005 | 09:16 PM
mason55's Avatar
mason55
Thanks for the help. Why do You think that it would be too much? I was planning on getting a Mummerts intake for a 4 barrel and using a 600 cfm holley on that? Is kinda looking for performance increase with the carb. on it. Will this not do it?
Mason
Old Dec 4, 2005 | 09:30 PM
pcmenten's Avatar
pcmenten
Installing a carb that's too big reduces part throttle metering accuracy, especially with a 2bbl carb. I'd be looking for an Autolite 4100 or a Holley 450cfm carb, not a 600cfm carb. You might consider getting a ECZ-B iron intake, it will make your engine quieter than with an aluminum intake and it will perform better when cold.
Old Dec 4, 2005 | 09:56 PM
mason55's Avatar
mason55
Would a 350 cfm be a wiser choise? The reason I am trying to go this way is that I already have the 2 barrel intake. Was just thinking that this would be a cheaper route w/o spending the money for a new intak and carb when I have this. Also I was thinking that the 2 barrel would be cheaper to buy for one and more fuel efficiant? You will have to excuse that lack of knowledge it has been a long time since I have tinkered with auotmotive stuff.
Old Dec 19, 2005 | 07:46 AM
Icicle's Avatar
Icicle
a 500 CFM carb is fine......
As long as it is NOT a 2bbl.... thats a large Venturi diameter for a 2bbl I think thats probably what 286 merc meant
a 500 CFM Edelbrock 4bbl would be a nice choice for a Y IMO, you would probably have to jet it down to 4% leaner at cruise and power modes, but its only a rod change, which is 2 screws and 2 minutes, and an $8 set of metering rods I could walk you through it easily if your not familiar with the procedure.
I think it would provide excellent crisp throttle response and decent mileage, with the other two barrels standing by for fun time
mason55
13
Jul 27, 2015 01:08 AM
mason55
Jul 13, 2015 09:01 PM
JayFan
Mar 4, 2015 09:22 PM
NateTheGreat
Feb 9, 2015 09:08 AM
49f3dls
Dec 17, 2014 02:03 PM
