intercoolor
Old May 20, 2013 | 07:19 AM
tjc transport's Avatar
tjc transport
i ain't rite
Originally Posted by idiabuse
I smoked two pistons wich had me rebuild my IDI twice.
Now it has an intercooler and it has made it past 10,000 miles
without smoking a rear piston like before without using an intercooler.
The power is much better the engine behaves much better and
my EGTs are below 1000F when running it hard.
My actual psi went from 12psi MAX to over 15psi I need a 20psi gauge now.
But driving it is easy to get the power I need at about 12/14 psi.
Intercooler=less engine damage
Javier
you did not melt the engine because you did not have a intercooler, you melted the engine because you had the fuel turned up too high and ran high EGT's.
i have put over 480,000 miles on my 88 without an intercooler, and never once saw EGT's over 900 degrees.
Old May 20, 2013 | 04:25 PM
Johnny L's Avatar
Johnny L
Originally Posted by Red454sedgwick
the turbo is a big heat exchanger, you have hot air on one side and cold on the other, when hot meets cold they have to even out the best it can, there is around 300F diffrence on the exaust temp in front and behind the turbo
The compressed intake air is NOT hot because the turbo acts as a heat exchanger evening out the temperatures. It is hot because when a gas is compressed it gets hot. The opposite is also true, that's why the propane tank on a BBQ gets cold. Intake air on a belt driven supercharger would also get just as hot from the compressor even though there are no hot exhaust gases going through the supercharger. Intercoolers are a great upgrade for both turbocharged and supercharged engines because they remove the heat in the intake air that was created during compression.
Old May 20, 2013 | 04:42 PM
turtlemann14's Avatar
turtlemann14
I don't see how that would help, you could wrap insulation around it, but it is still tied to the hot block, the heat will travel through the metal
insulate it from the heads. i know i can get plastic spacers for the intake on my car, just curious if something would be possible for our trucks.
Old May 20, 2013 | 05:07 PM
Red454sedgwick's Avatar
Red454sedgwick
Air being compressed dose create heat, that is what make diesel's run, That is very important and I skiped over that fact,
But jonny are you saying that the 600-1200 degree air on the hot side of the turbo that is conected to the cold side by a bunch of fins that not only compress air or drive the trubo, also act as heat sinks. dosen't matter all of the heat that you would be trying to get rid of is from compression it's self.
The igtion temp for diesel is 410f it takes at least 260psi of crancking pressure and the help of glow pulgs to reach that on a 6.9
Old May 20, 2013 | 05:20 PM
Red454sedgwick
Anything is possable, except for me learning to spel right, You would have to do a custom intake
Old May 20, 2013 | 07:19 PM
idiabuse's Avatar
idiabuse
That is possible but it was a combination of issues.
Yes fuel turned up possible, but bought the truck in 99 and never
pulled the plate to adjust.
Did rebuild the IP later.
A combination of issues help score the cylinder twice for me.
Lower hose collapsing shut at road speed.
And the lack of intercooler with a well built IP.
I did have an EGT gauge and monitored it, never noticed it over
1000F
Anyway it is handleing my abuse now just fine.
Javier
Old May 21, 2013 | 01:17 AM
Fordidipower's Avatar
Fordidipower
Cylinder walk scoring is caused from:
Damaged rings on installation or age or ping or whatever
Oil- bad dirty old oil that can't do it's job cuz it's worn out
Clearences- if the clearances don't allow oil to pass down the Mains to be flung on the walls then they will scrape the walls. Bad clearances can be poor machine work, old age, installation errors
Or maybe oil pump has seen better days.
Pistons don't just hit the cylinder walls for no reason either oiling system or oil itself is the problem. Plastiguage can tells a million stories
Old May 21, 2013 | 03:24 AM
ozdatman's Avatar
ozdatman
And over heating can cause scoring
Old May 21, 2013 | 12:56 PM
Fordidipower
Ya but the cause of heat needs to be determined as well
mrxf350
Oct 20, 2017 05:03 AM
75Three90
63
Jun 5, 2016 11:19 PM
JHoffman93
Apr 6, 2013 03:48 AM
rclyde99
Feb 13, 2012 11:29 AM
boots6868
Dec 11, 2008 05:20 PM
