Rancho 9000 settings
Old May 18, 2013 | 08:45 AM
labman1014's Avatar
labman1014
I have a 2000 Ex 4wd 162k miles. 1yr old brand new V codes on the front. Original rear springs with 3.5" block.
My new Rancho 9000s will be here tomorrow. What is everyone running settings wise and what would r recommend or starting with?
Tks!!
Old May 18, 2013 | 09:23 AM
Misky6.0's Avatar
Misky6.0
Common practice is 5, in the middle.
But i think try 9 first the most damping, so you learn the max setting.
If it is too harsh go to 1, so you can get the mushy feel. I doubt a 1 number change can be felt so go 7 then 3 then last 5 if needed.
I have 2wd, 9 in front, 5 in back, easy to change but finicky **** with NO markings. Don't turn it beyond 1 or 9
Old May 18, 2013 | 10:10 AM
Patriotic Rottweiler's Avatar
I have the Wireless My Ride installed and that is the way to go so that you can adjust on the fly. I like the mushy feel so I run 2 front and 2 rear with stock springs. Plus I live on a bumpy dirt road. Plus when I tow, I just hit a button and change the setting from the drivers seat.
Old May 18, 2013 | 12:08 PM
jdw1's Avatar
jdw1
On the 05 Ex, I run them on 1 unless towing.
Towing, 3 in the front and 5 in the rear.
On the 02 F-350, 3 in the front and 2 in the rear unless towing.
Towing, 4 front and 6 or 7 in the rear, depends on how much weight is on the goose neck.
Snowplowing, 6 up front and 3 in the rear, snowplow weights is about 900 lbs.
The 2000 Ex has Bilstiens on it, no adjustment.
Your settings may vary!
Just play with it you will notice the different settings.
Old May 18, 2013 | 01:20 PM
labman1014's Avatar
labman1014
Tks guys!!!
Old May 19, 2013 | 08:52 AM
sccamper's Avatar
sccamper
I run mine on 9 when towing camper and 5 when not towing. Tried running 3 while unloaded but it felt to soggy. I was surprised how much of a difference you can feel by turning the dial. Rear shocks had been installed before I purchased Ex. Want some for the front too.
Old Jun 10, 2013 | 09:42 PM
fishintheobx's Avatar
fishintheobx
Anyone else? My truck goes in at the end of this week to have 4 new RS9000's put on, steering stabilizer, RAS, 6.0 belt tensioner, and new belt. Then 3 adults and 3 kids are setting off for a 1200 mile trip. Guess I'll start them around setting 5. Really looking forward to seeing what the new ride with the Ranchos and RAS is like!
Old Jun 10, 2013 | 10:05 PM
Sunline Fan's Avatar
Sunline Fan
Excursion Fleet Manager
Ran them at 3 all the way around on my last Excursion, and the same here on this one too.
lionsteve
Jan 29, 2014 11:32 AM
MTMike
Oct 26, 2013 10:09 PM
pin8246
19
Jul 13, 2012 08:44 AM
speed
Jul 12, 2011 12:51 AM
tjthegreat
Feb 7, 2008 09:13 PM
