This is for the guys that tow quite a bit. I tow almost everyday about 6k lbs, I know its not much, but between my Dodge and Ford, the Ford sags a lot in the rear. What type of setup are you guys who tow running to get rid of this? Just rear airbags or what?
I tow a 11,500 lbs Toybox with 1,400 lbs tongue weight.
So im looking at these. Basically if I got it right, it will be like the air ride system I had on my GP. Ill need to towing airbags in the rear (roughly 300$) and then the compressor setup (roughly 600$). Right?
Its going to have to be the springs then. The truck is new to me, but has 200k, so no telling when the springs were done last. It drops about an inch or two when I hook up. Its properly hooked, all drop hitch and trailers have been measured for the height im sitting at.
Since we have got that pretty much figured out. Im seeing all the options to raise a truck front and rear by the leaf springs. Im also seeing some lifts for the rear that are heavy duty. Can I use these to raise my truck and also tow.
I have a 02 F250 PSD and tow a Toy Hauler that when it is fully loaded is about 10,000 pounds and it don't really sag at all. I would say your springs are weak. I have air bags from firestone also for when I pull heavy loads like my buddys Tag trailer they are great but pay a little extra and get the onboard compresser it will make you life a lot better.
