Did a compression test today.
Old May 17, 2013 | 03:17 PM
Rod Beauvex's Avatar
Rod Beauvex
93 F150 L6 XL. ODO says 308,000, though engine is supposedly no original. No way to confirm either way.
Plugs were clean, and all cylinders were +/- five percent of 120lbs / 800kpa.
Another thread suggests this is on the low side. Any thoughts?
Old May 17, 2013 | 04:27 PM
Phy's Avatar
Phy
It's usually more important that the cylinders are close, than the actual number.
The test procedure matters a lot...
Did you test it warm or cold? Have the throttle wide open? Let it turn over through 5 or 6 compression strokes?
Old May 17, 2013 | 04:51 PM
Rod Beauvex
I did test it warm. I did not test it wide open though, as I had forgotten about that at the time.
Old May 18, 2013 | 12:56 AM
GoinBoarding's Avatar
GoinBoarding
Air pressure makes a big difference too. I've tested my snowmobile at 800 ft and seen 155psi, that same motor at 7500 ft was 115psi. Air pressure drops, to a rough approximation, 3% per 1000' of altitude. So guys at sea level will think a guy in Leadville, CO (10k ft) has a trashed engine if they see his compression test results.
An oiled cylinder will also seal much better. Some gauges leak too.
The fact that all your readings are within 5% says the motor is doing fine. Now use those readings as a "health baseline", so if in the future you suspect something is wrong, and measure compression with the same gauge, and find lower readings, you know the motor is going south.
Old May 18, 2013 | 07:50 PM
Rod Beauvex
Ugh, well, I just went through the process again, and I got about the same figures with holding the gas pedal down. The motor was tested hot, and I did not bother with a wet test.
Old May 18, 2013 | 08:54 PM
GoinBoarding
I'd just keep driving it and not worry.
c2z4s9
73
Feb 29, 2016 07:14 AM
vshack
Sep 16, 2010 07:41 PM
MONAVIERONJON
Oct 15, 2009 11:50 PM
twisted
1978 - 1996 Big Bronco
Jun 2, 2007 12:28 PM
tractoman
Feb 19, 2006 02:18 PM
