Compression test how to?
Old Oct 14, 2009 | 05:39 PM
MONAVIERONJON's Avatar
MONAVIERONJON
Been driving these for yeaars and finally got me a diesel,so i am anxious to do a compression test on my motor (7.3) and it is a late 80's model.What are the basics to this process.It seems as if there is a compression test kit for a diesel aFord able @ Harbor freight,so when I get one then what would be recommended for an accurate test?
Old Oct 14, 2009 | 06:12 PM
farmnfly's Avatar
farmnfly
Its not neccessarly the pressure but more that all cylinders are at the same pressure usually around +/- 10%. If one cylinder is much lower than the others, then there is possible problem with that cyl. valves, rings, cam, rocker, pushrod, head gasket, liner etc.
Old Oct 14, 2009 | 11:28 PM
PLC7.3's Avatar
PLC7.3
Actually the lowest cylinder must be no lower than 75% of the highest...... Never use oil in the cylinders, the test must completed on a warm engine. Crank the engine over at least 5 pumping strokes per cylinder (ignition off). Record the highest reading and number of strokes to get there....... do all the rest the same way.
Old Oct 15, 2009 | 11:50 PM
GenLightening's Avatar
GenLightening
Some that have bought the HF set haven't been happy with it (I got one and have not used it yet). Make sure the correct adapter is included. The one I got had to be modified to work. Some have also had the gauge fail after only a couple of cylinders.... May want to get a quality set to start with.
