abnormal shifting
Old May 17, 2013 | 11:45 AM
1997fordf350's Avatar
1997fordf350
abnormal shifting
Hi, when i am going about 55 my transmission sometimes starts downshifting and then up shifting again for no reason. Any thoughts?
Thanks
Old May 17, 2013 | 12:58 PM
projectSHO89's Avatar
projectSHO89
Lots of thoughts... Which ones do you want?
Might be completely normal, might not - you haven't given enough details one way or the other. All I can conclude is the transmission is probably shifting in and out of overdrive, most likely. Might be engine management, gear/drive ratio, load, terrain, altitude, or maybe, nothing at all.
Old May 17, 2013 | 01:42 PM
1997fordf350
Is it anything to worry about?
Old May 17, 2013 | 03:19 PM
projectSHO89
You're already worried about it or you wouldn't have asked. Like I said above, you haven't given enough details one way or the other.
Old May 17, 2013 | 04:49 PM
85e150's Avatar
85e150
Thanks
Is this your '97 F350?
What engine, trans, tire size, gear ratio?
Any history on the trans?
Any recent changes, like larger tires or trans work?
Rain storm, pressure wash, flood, fire, pestilence?
Old May 17, 2013 | 04:57 PM
1997fordf350
1997 f350
7.5 e40d
No history
Just wider. Not by much
And none
Old May 17, 2013 | 09:19 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Most likely the Transmission Range Sensor (TRS) is failing. It's located on the driver's side of the trans. It is the only part that has a wiring harness attached.
Old Jun 9, 2013 | 03:56 PM
1997fordf350
Ok so I had to get the computer replaced and it went away for like a week. Now it started back up again?
Old Jun 9, 2013 | 08:13 PM
Mark Kovalsky
As you now know it isn't the computer. I think the answer is below.
Old Jun 12, 2013 | 03:11 PM
1997fordf350
Would it be when it's hot. It does after it's been running for a while
Old Jun 12, 2013 | 05:37 PM
Mark Kovalsky
Yes, it often gets worse as it gets hotter.
I once was trying to catch a TRS doing this. I had a vehicle that occasionally would act up. I drove it 500 miles one day trying to make it do this. I finally gave up. It happened as I was turning into the parking lot.
Old Jun 13, 2013 | 11:17 AM
1997fordf350
So for sure it's probably the TRS
Old Jun 13, 2013 | 12:58 PM
Mark Kovalsky
I can't be sure, but it is very, very likely.
Old Jun 25, 2013 | 08:33 PM
1997fordf350
Is it easy to replace
Old Jun 26, 2013 | 08:21 AM
Mark Kovalsky
Yes, it is very easy. 10 minutes tops.
