Excursion V10 Piston depth
Old May 17, 2013 | 09:24 AM
Homer Simpson's Avatar
Homer Simpson
Hello all,
Does anyone happen to know distance between the head and the piston at the bottom of the down stroke?
I am about to enter the rite of passage known as Time-Sert spark plug repair and it says that the piston needs to be away from the head while boring it. Rather than removing the cover/head I was going to stick a dowel down the hole the check the piston position.
Is there an easier way?
Once I get through the Time-Sert ritual, I know I'll be a man (he says as a tear wells up in his eye).
Thanks for your help
Old May 17, 2013 | 12:50 PM
Stewart_H's Avatar
Stewart_H
You shouldn't be going so far/deep as to hit the piston. Making sure it's down/away from the head is just a safety margin to prevent an "oops" and keep errors from occurring.
Pull your fuse for the fuel pump and put your finger over the spark plug hole and then have someone bump the starter. When you feel suction on your finger the piston is moving down and you'll have your clearance.
Stewart
Redsworld3
Mar 4, 2015 03:03 PM
jwood2326
Aug 7, 2010 11:45 AM
Nitramjr
42
Oct 13, 2009 10:07 AM
zoey
Mar 24, 2007 12:27 PM
1987bluef250
Nov 22, 2003 02:01 AM
