Fuel Gauge Question
Old May 17, 2013 | 08:45 AM
UGA33's Avatar
UGA33
Fuel Gauge Question
Been around OBS trucks all my life and finally picked one up as a secondary vehicle to keep the miles off my 6.4. A little history on the truck. It's a '97 F-250 regular cab long bed 4x4 5-speed. Cousin was tired of dealing with little issues so he parked it and I bought it from him. His biggest issue was bio diesel. The rear tank, both sending units, fuel lines, and selector valve were all trashed. Took front tank off, cleaned, and replaced sending unit. Didnt put a new tank in the rear just left it off. Ran new supply and return lines up to the motor and replaced mechanical pump in the valley. Also removed the selector valve. Truck runs great. Does my fuel level gauge problem stem from the selector valve not being there? If so, could I just get the old one back on and plug it up? Should this correct my problem? New to the intricacies of the OBS trucks.
Old May 17, 2013 | 09:02 AM
farmert's Avatar
farmert
Yes, the fuel selector valve completes the circut for the fuel gauge. I don't remember the colors of the wires, but you could experment jumping the wires on the wiring plug, and when you find the right 2 it should make the gauge work, if the sender isn't FUBARed.
Old May 17, 2013 | 09:23 AM
Hussler's Avatar
Hussler
Yellow/White wire goes to fuel gauge ...
brokeasajoke
Jul 11, 2013 02:21 PM
FordOwnerJoey
16
Apr 17, 2013 09:53 AM
T_F_E
Apr 1, 2012 09:10 PM
grizzen
Sep 25, 2011 09:26 PM
Johnnyvolvo
Jun 8, 2003 09:18 PM
