Oil Change Problem
I've had the van since mid February. I bought it used from Car-Max and we really like it. I did my first oil change on Wednesday. The filter felt spongy as I tightened it, but didn't think much of it.
I get home yesterday and my wife was in town in the van...I see a puddle of oil on the garage floor and call her immediatley. It was maybe a 1/4 cup (a lot, but not a dump). I'm not one to overreact, so I tell her that as long as no lights or bells come on to bring it home.
When she came home I take a look and the gasket from the filter is popped out in an area. Oil was still in the crosshatches, but not by more than 1/8". I checked the filter I took off, and sure enough, it had no gasket on it. So, that's my diagnosis.
Now my questions...
Think I can pull that filter off without draining the pan? Maybe even just loosen it enough to take the old gasket out. The filter seems higher than the pan so I think it should work. It would be messy and a pain to drain it to a pan, pour from pan back to big jug, and then back to the engine.
Although, if I go the jug route, I could measure better. But I could just use the dipstick too.
PS: I was happy to find the filter had the great mounting location and wasn't a PIA to get to, like mounted on the block.
Thanks for insight and advice!
Nathan
I have done this in the past when the dealer put a non-Motorcraft filter on my van and I got a knocking at startup because of a bad anti drainback valve.
And I *once* put on a new filter with the old gasket stuck on the surface without checking and proceeded to pump about 3 quarts of oil onto my driveway on initial startup. Good thing we have a cat and had a couple big bags of kitty litter in the house.... I will NEVER again change an oil filter without confirming that the old filter gasket has been accounted for. (I will also note that when I was 19 years old, in 1971, I changed the oil the first time in my old Austin Healey 3000, which had a cartridge filter in a can with O-ring gasket, did not get it seated properly, and pumped out about 3 quarts of oil into my girlfriend's parents' driveway...deja vu)
No worries in the slightest. By the way, use Motorcraft filters whenever possible (do a search on this website). Good luck with your van,
George
I'm not too brand loyal, I will look up the Motorcraft info. However, the motorcraft filter I took off was the one that left the gasket.
My local autozone runs specials of filters and 5 qts of oil for $20. So I usually just get whatever's on special. Now with the 5.4 though I am sure to get the extra qt.
Thanks again!
And *if* your engine ever needs warranty work and it turns out that a filter imploded, your dealer could deny a warranty claim if it was anything other than a Motorcraft filter, so for that reason alone, I'd recommend them. But do some reading, search for websites that show filter internals, and good luck with your van.
George
That said, they cannot deny a warranty claim because of non-oem components, unless that component caused the failure.
At 42k miles, my 4.6 developed a light ticking noise. The factory had issues a TSB that the early 4.6 Romeo PI heads (like mine) had bad cooling on the rear exhaust valves, and the Ford fix was replacement heads. At the time, the powertrain warranty was 36k miles, but I had bought an extended 60k warranty. The service manager, who knew me by name, got me a loaner car for a week and $4200 worth of new cylinder heads for my $100 deductible. I don't think my using Motorcraft filters really mattered, nor was the problem caused by oil or filters, but during warranty periods, I do my best to use the dealer for oil changes.
And I still believe that if you brought a vehicle in with the OEM model Motorcraft filter that disintegrated and killed your engine (as would be evidenced by cutting the filter apart), that it would be covered by warranty, whereas if it was a Fram (and I HAVE heard stories of them blowing apart--not often--but they are cheap junk with pretty orange paint) I think you'd be SOL. Fram might provide *some* coverage under their warranty, but good luck on that....
It is my belief that if you have an engine failure under warranty using Motorcraft oil and Motorcraft filters on a documented basis, that you would be covered under warranty. I have not tested this directly, but got a huge warranty repair without any pushback while doing so.
George
I NEVER use the "on special, free" filters offered regardless where or what brand oil I'm buying. They're "free" for a reason and it ain't good!
Can't tell the players without a program. Always make sure you get a silicone ADB valve.
George
Agree that a free filter if its of the better or best variety is never a bad thing. Most times that's not the case though, pays to know its details and specs though.
On several occasions my preferred Ford dealer will run an unadvertised special on those I use---always get at least 6 or so for my own stash. $5 each seems a good price.
I was able to change the filter w/o drianing the oil. Then we went on a family vacation of 700 miles and just got back last night. So all is well!
Thanks!!
The ADB will be present on most any good, better or best filter spec'd for your motor. Always a good idea to go with good stuff since you know its made to fit your vehicle.
