Rebuilt 390 question
Old May 16, 2013 | 01:52 AM
Lostownloser's Avatar
Lostownloser
I just had my 390 rebuilt and had it for about a week it has a performance cam, intake manifold, headers and exhaust and a Holley 4 barrel. After driving home last night I noticed it was dripping oil lost maybe a quarter of a quart of oil I tightened the oil lines where it seemed to be coming from but was wondering if this could be expected or should I take a deeper look into it. This is my first engine build and I'm not too skilled in all of this any help is appreciated thank you.
Old May 16, 2013 | 05:55 AM
jowilker's Avatar
jowilker
Check the top of the engine at intake manifold and valve covers. Did you use new covers, if you reused did you block them to get them flat? You could have damaged the seal when installing the intake.
John
Old May 16, 2013 | 09:00 AM
MIKES 68 F100's Avatar
MIKES 68 F100
1/4 of a quart is alot ! you should be able to follow it to it's origin , new engine shouldn't have leaks , something might have vibrated loose so double check everything .
Old May 16, 2013 | 04:56 PM
Lostownloser
Thanks for the replies guys I'm having some other problems with it so back to the mechanics it goes but thanks again.
Old May 16, 2013 | 11:48 PM
85e150's Avatar
85e150
Oil lines? You have external oil lines?
Sure you don't have a transmission cooler line leak?
Old May 17, 2013 | 03:25 PM
montana_highboy's Avatar
montana_highboy
Originally Posted by 85e150six4mtod
Oil lines? You have external oil lines??
That caught my eye too, I just assumed he meant the line to a mechanical oil pressure gauge.
Old May 19, 2013 | 10:58 AM
RustyTrustyF150's Avatar
RustyTrustyF150
biggie is getting the intake manifold down without disturbing the front and back intake manifold gaskets .
Old May 19, 2013 | 05:59 PM
69cj's Avatar
69cj
Don't use them. Run a 3/8's bead of ultra black rtv, let it get tacky, app. 15 min, and set the intake down. I use an engine hoist and two pieces of threaded rod in the block to let the intake drop on square with no side movement. One rod front left the other rear right or reverse. Your choice.
Old May 19, 2013 | 07:23 PM
montana_highboy
Toss those cork end gaskets in the garbage, i like to "dimple" the china walls for better adhesion (bite), and use Motorcraft TA-31 sealant (the gray stuff), better than the black/blue RTV, guaranteed leak free. Give it a try.
Old May 19, 2013 | 10:30 PM
RustyTrustyF150
I have tried the silicone idea once and never again
Old May 20, 2013 | 01:03 AM
montana_highboy
I'm assuming user error?
Old May 20, 2013 | 08:50 AM
MIKES 68 F100
i used the cork gaskets , just glued them to block in place with gasgacinch let dry then installed intake with a little permatex#2 no leaks ...
Old May 20, 2013 | 10:22 AM
Buzz44's Avatar
Buzz44
Sounds like patients is the key along with a strong back or better yet an engine hoist if using a stock 4 barrel manifold. All good info to follow when I get ready to change my 65 352 FE over to a 4barrel.
Martin Torres
Sep 23, 2016 12:08 AM
37 Ford guy
Sep 15, 2009 08:53 AM
JDenver
Nov 7, 2006 08:34 PM
HeapBigEngine
Apr 20, 2006 11:07 AM
Fast68F100
15
Oct 1, 2002 12:06 AM
