Fuel level sending unit
Old May 13, 2013 | 11:35 PM
Rishsd's Avatar
Rishsd
I have added a rear tank to my 2000 f250. It came with the original fuel sending unit that is a 0-12v. I want to add this tank to my DP-tuner infinity, the new box that is coming out soon accepts (8) 0-5v sensors so I need a new sending unit that operates at 0-5v. Does anyone know of any sender that would work?
Question: if I just put 0-5v to this sending unit and ohm it out to find full and empty will this still work?
Old May 13, 2013 | 11:39 PM
woodnthings's Avatar
woodnthings
Call up ISSPRO and see what they can do to build you a sensor. They can make any kind of sensor if you know the requirements.
Old May 14, 2013 | 08:00 PM
Rishsd's Avatar
Rishsd
I called ISSPRO today they told me I would have to cut a rather large home in the top of the tank and install a tube fuel sending unit costing $150.00. For that cost I will just put a aftermarket fuel gauge in if for $25. Thanks for the recomadation.
Old May 14, 2013 | 09:01 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I'm curious how you plumbed your tank.
Old May 14, 2013 | 09:07 PM
Rishsd's Avatar
Rishsd
This is for a WVO conversion. This one is going to be deadheaded to the test ports. I originally had the second tank to a pollock valve with a switch in the cab.
Shorty 66
Apr 21, 2009 07:44 AM
cana55
1947 and Older Ford Trucks
Feb 22, 2009 10:25 AM
hivolt5.0
Oct 23, 2008 01:38 PM
78blueford
Mar 12, 2003 11:21 AM
